Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 11-13-2002, 07:06 AM
narcted narcted is offline
E-Brake Spin Turn Knob
I want to modify my e-brake so that it doesn't ratchet when I pull up on it. I've heard of a part called a spin turn knob. Basically you take off the OEM brake knob, remove the spring, and replace them with a spin turn knob. This way you can still lock the brake when you park, but it won't ratchet when you pull up while driving.
Has anyone else heard of this part? Does anybody know where I can get one? Has anybody done this?
Old 11-13-2002, 08:30 AM
muphasta muphasta is offline
Send a message via AIM to muphasta
Can't you just push the button when you pull up?
Old 11-13-2002, 04:26 PM
That's what I do now. It's rather bothersome and annoying. Sometimes I'm moving so fast I don't get the e-brake all the way down. It would be much easier if I could just give it a quick tug and not have to worry about the ratchet. I just need the brake on for only an instant to get the rear wheels to slip. When that happens I need both hands to steer.
Old 11-13-2002, 07:12 PM
AAAAhhhhhhh, I see. Silly me! you are using it to slide! My bad
Old 11-13-2002, 07:20 PM
hinggu hinggu is offline
there is a cheap way to do this if you want. you have to press your button and then drill a hole though it. then drop a cotter pin though it. if you want to use it to park, you have to remove it thouhg
Friends Don't Let Friends Drive Stock-K&S Racing Development
www.kandsracing.com
AEM CAI
Custom Apex-i N1 cat back
Front end grinding when turning and braking rlb5390 Alero 5 02-11-2009 10:19 PM
Springs/Brakes/Spin Wess-RA GTRA / GTWS / GTS 30 01-07-2009 11:17 PM
My brake lights, turn signals, and turn signal indicator lights aren't working. HeatherMarie Engineering/ Technical 3 02-09-2006 02:47 AM
Drift Spin Turn Knob... GSR2NR94 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 06-12-2005 08:30 PM
spin turn knobs TheLogikal1 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 5 02-18-2003 04:05 PM
