Old 02-07-2006, 07:17 PM
HeatherMarie HeatherMarie is offline
My brake lights, turn signals, and turn signal indicator lights aren't working.
My running lights and hazards work, so I know the bulbs are okay. I've checked the fuses in the dash and under the hood. What else could it be? Please help.
Old 02-07-2006, 08:42 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: My brake lights, turn signals, and turn signal indicator lights aren't working.
What year, make and model car?
Timeslip 08/12/06
AF Community Guidelines
Old 02-08-2006, 06:03 PM
It's a '94 Olds Cutlass Supreme
Old 02-09-2006, 02:47 AM
Akira13126 Akira13126 is offline
Send a message via AIM to Akira13126
Could be a broken wire, a bad relay or a bad switch. If you can take out the switch and check each termainal(sp) with a test light or a multi-meter. Also make sure that there is power going to the switch. Hopefully this points you in the right direction.
Akira
