Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 08-06-2007, 01:36 PM
burakis123a burakis123a is offline
Question 02 Chevy Venture. Windshield Washer prob
Having a problem with chevy venture where the wipers will sometimes not work and the washers don't work period. The washer pumps seem fine and the fuses are ok. I'm guessing the problem is in the steering column (switch etc.) Was wondering what i probably need to pull off a junker and use to replace on van. The turn signals/cruise control works fine btw. Also if you try to run the washers the wipers work but nothing sprays. Any help is appreciated in tracking down this annoying problem.
Mike
ps. Wipers on occasion will stop working mid-swipe sometimes. Then will start working again
Old 08-06-2007, 02:54 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: 01 Chevy Venture. Windshield Washer prob
Have you checked for any blockage in the washer fluid hoses that carry the fluid from the pump to the nozzles? Maybe some debris got in the line, or the hose itself got crimped by something blocking the flow of fluid.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 08-06-2007, 05:12 PM
Cool Re: 01 Chevy Venture. Windshield Washer prob
didn't but it couldn't be that. Even if they were obstructed i should be able to hear the pumps going. Also used multimeter to check power going to wipers and washer pumps when turned on. Wipers had power going to them but the pumps did not. Maybe this extra info will point to a possible source. Again the wipers sometimes die mid swipe and so i'm guessing they lose power....somehow both problems are tied to a failing part somewhere.
Any help appreciatedopcorn:
Mike
Old 08-08-2007, 11:07 AM
acemech128 acemech128 is offline
sounds like pulse wiper module failure, module is located on motor
Old 08-14-2007, 02:44 AM
Ididnt[BreAK]it Ididnt[BreAK]it is offline
check the ground..
if there good then the pumps/motor are dead
