Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-04-2007, 10:02 PM
tboneshep tboneshep is offline
Diagnostic codes with paper clip-Cutless Supreme
1991 Oldsmobile Cutless Supreme, 3.1--no spark
When I use the paper clip method to get the codes, (Service Engine Soon)
and connect A to B, I get nothing exept the Service Engine soon light, and the Main cooling fan turns on. What am I doing wrong? Thanks
Idiot at work
Old 08-05-2007, 12:18 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Diagnostic codes with paper clip
Is the SES light flashing when you are doing this? You need to count the flashes to determine the codes. The first code to appear will be "12", one flash, pause, two flashes, which will be repeated 3 times. This lets you know that you have successfully have sent the computer into its diagnostic cycle. After that there will be a pause and the stored codes will appear,( example Code 23 will be two flashes followed by three.)If there are no additional codes after it has flashed "12" during the first sequence, it will flash "12" again .
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
