Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-02-2007, 08:17 AM
sirjonas sirjonas is offline
fan not working
my fan for the interior is not working on the number 5 setting. does anybody have any ideas what might be causing this? my van is a 2002 montana.
Old 08-04-2007, 07:40 PM
1999montana's Avatar
1999montana 1999montana is offline
Smile Re: fan not working
Have a look at this thread: http://www.automotiveforums.com/vbul...d.php?t=667887
I think you may find, once you get it out, that the blower resistor is blown on one or more taps.
However, speed position 5 should be full voltage, by-passing the resistor entirely, so you may want to check for a loose connector, or burnt wire first.
Come back to the board after you've had a chance to check, and let us know how you make out.
Old 08-07-2007, 07:38 PM
Re: fan not working
Wherabouts would i look for the loose wire or burnt wire? And the resistors, where would i find them? thanks
Old 08-07-2007, 09:03 PM
Well, if the internet would make it possible, I guess anyone could point you in the right direction. But that not being the case, you will need to take some ownership of finding the wires and tracing them back.
My advice would be to trace all of the wires from the fan motor (located under the kick panel that is attached to the underside of the passenger side dash).
Follow the wires back to the switch and to the resistor mounted in behind the blower motor in a very inconvenient place near the firewall, just to the left and attached to the underside of the heater plenum.
I believe this web page showing the wiring diagram belongs to GregA: http://www.my-chevy-venture.com/blow...resistors.html
Old 08-15-2007, 09:21 AM
Re: fan not working
ok i am finally getting around to trying and figuring out why my blower fan is not working on high. i checked all the fuses and they are fine. The relay that is in the fuse panel works as well as i switched it with another relay and got the same effect. so i pulled out the resistor pack and i only have 2 resistors on my little board and they both looked fine. i could not find any wires that were burnt off or corraded. so i pulled the resistor pack apart because there is a relay inside of it. when i had the fan on the number 4 setting there was about 8.4 volts running to the fan, when i switched it to number 5 the relay clicked so it was in the close posistion and nothing would happen. does this mean that i have to replace this unit?
Old 08-15-2007, 09:29 AM
Re: fan not working
The price for a replacement assembly is 44.50 canadian so i just might go ahead and replace it, but i am gonna look some more for some loose wires
Old 08-15-2007, 07:05 PM
...when i switched it to number 5 the relay clicked so it was in the close position and nothing would happen. does this mean that i have to replace this unit?...
What is the voltage reading with the switch in the number 5 position and the relay closed? It should be battery voltage.
If it is lower than the battery or non-existent, you have a bad connection or an open somewhere between the blower motor, relay and the ignition/battery source power. It could indicate that the relay has 'gone south'.
If you are getting increasing variable voltage levels on all other positions (1-4), the resistor pack sounds like it is still working OK.
When you examine the pack there is a two-sided circuit board and what looks like two horse shoe shaped resistors. (I'm doing this from memory, so bear with me)
If there is some scarring or burning of the circuit board material, the pack is going bad.
Old 08-16-2007, 12:07 PM
Re: fan not working
ok i got it working now. i had to replace the resistor pack. the voltage was reading 0 when the switch was in the number 5 posistion. i new pack was alot better then the old one was so hopefully this never gives me trouble again. It must have been the relay had gone south. thanks for the help
Jonas
Old 08-20-2007, 10:11 AM
Uncle1957's Avatar
Uncle1957 Uncle1957 is offline
Re: fan not working
Congrats on getting it working.
My 2002 Montana is doing the identical thing.
Where is the resistor pack located.
I will start by replacing that.
Thanks
Gord
Jonas
Old 08-20-2007, 01:43 PM
Re: fan not working
The resistor pack is located on the passenger side underneath the dash. you will have to pull carpet off that is attached to the bottom of the dash and runs to the just above where your floor mats are attached. once this is off you will see your blower motor, if you look behind the blower motor in the little tiny space that is there you will see a rectangular box that has two wires coming out of it that is hooked up to the blower motor and one plug with 5 or 6 wires in it. this is the resistor pack that is more then likely not working. there is three bolts holding it in place. if you remove the one that is in the front and just losen the back 2 you should be able slide it towards the front a little then down. if you need any more help just let me know
Old 08-20-2007, 01:45 PM
Re: fan not working
oh and i forgot to mention that it is a major pain in the ass to get up in behind the blower motor as there is very little room to work up there
Old 08-20-2007, 04:31 PM
Uncle1957's Avatar
Re: fan not working
LOLOLOLOLOL
I think that is the unwritten law of car repair...
Thanks for the info.
Gord
Old 08-21-2007, 10:18 AM
Re: fan not working
Your welcome.
Old 08-24-2007, 09:35 PM
mdhbhouse mdhbhouse is offline
Re: fan not working
Glad I found this post, looks like my problem on a 2002 Venture as well except doesn't work on setting #2.
Old 08-28-2007, 12:14 PM
Re: fan not working
yes i believe this is the same problem except one of the resistors will be burnt out on your pack.
