Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-27-2007, 02:37 PM
1999montana's Avatar
1999montana 1999montana is offline
Smile Heater Motor Resistor
Here's an FYI for all,
Last oil change, when I backed the van out of the garage, I noticed that the heater was not blowing any air out the vents. It wouldn't work on 1, 2 or 3 but would on 4 and 5.
Figuring it had to be the resistor, I proceeded (in ever reducing daylight!) to remove the dash kick panels and the heater motor to get more access to the resistor. A flexible shaft 3/8 would help, but unfortunately there isn't a lot of room between the screws and the floor pan to get a good socket on them. Small channel locks are useless, as are small vise grips. I used a small ignition set to loosen the screws and the resistor slides out past the two back screws as long as you remove the one closest to you. It took me about a half hour (in a very awkward position) to remove the resistor.
Fortunately our Chev / Olds dealer a block or so away had one, in fact they stock these regularly...go figure...the new one actually looks like a heavy duty resistor with multiple taps to handle the different motor speeds.
Makes you wonder why GM didn't do it this way the first time, but then we already know the answer...easier to do it the cheap way and have it come back for repairs later. Great customer loyalty program...build it cheap so it will break more often.
Old 01-27-2007, 03:16 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Heater Motor Resistor
So if that's the case, one can guess that the parts dept. also stocks a lot of intake gaskets,rear circuit boards for the taillights, power window switches, wiper parts, etc.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 02-02-2007, 01:06 PM
kb0nly kb0nly is offline
My 97 had the same problem when i bought it, and it is a super pain in the butt to replace.
Mine was one worse though, i replaced the blower motor resistor, it was charred from the failure, and it still wouldn't work on 3 but worked on 1,2,4,5... I had to also replace the blower motor switch to get it working correctly again. I figure it blew out when it was on position 3 and that pulled enough current through the switch to damage the contacts or something in there.
Old 02-17-2007, 01:15 PM
redly1 redly1 is offline
hey...do you recall what the part number for the heater motor resistor was?
Old 02-17-2007, 02:01 PM
Smile Re: Heater Motor Resistor
Why yes I do!....Prt # 89018643...atleast it is in Canada...fits my 99 TranSport...imagine it fits a number of other years as well.
I think you'll find this is a good number Stateside too...
Old 02-19-2007, 03:34 PM
cdru's Avatar
cdru cdru is offline
If you can, go after market. It's likely the same manufacturer and usually will have at least the same warranty if not longer (mine was a year). It's also usually 1/2 the price.
Vinyl adds horsepower, right?
