Old 07-26-2007, 02:42 AM
rx_7rob rx_7rob is offline
digital dic wiring
color function location on plug
brown ign pwr in a2
orange battery pwr in a1
pink ign pwr in b9
lt.blu/blk left rear door indicator (ind) a12
blk/wht right front door ind b12
gry/blk left front door b11
lt grn/blk right rear door a11
black ground b4
black ground b5
lt blu engine managment switch b7
red/blk trunk adjar ind a10
tan computer data (mpg) a7
dk green vss signal b6
lt green low trac ind a3
purple/wht trac off indicator a6
brown/wht trac switch out b2
gray change oil indicator a9
dark blu/wht aux chime b1
gray pwm dimer b3
gray/blk vf park a5
blk/wht low washer fluid indicator b8
top side of plug is = a
bottom side = b
I hope this helps everyone that is interested in doing this mod
Old 07-26-2007, 04:17 AM
blackblazer24 blackblazer24 is offline
Re: digital dic wiring
Have you made the swap yet?
Old 07-26-2007, 08:36 AM
BNaylor's Avatar
BNaylor BNaylor is offline
I agree that is a good question.
Timeslip 08/12/06
AF Community Guidelines
Old 07-26-2007, 12:02 PM
I took a dry run on this mod today.I hooked all the wires up and I did not get the display to light up.The dic I have came off a 2000 grand prix and it seems that the wiring harness from the 2000 has some conflicting wires,example two brown wires (as mine only has one) and one gray wire ( mine needs two) and the tan data wire that controls the mpg and miles until empty,The problem with the tan wire is,where it hooks up you must splice into where the OBDII contects into the data block.I do not like the fact that you need to splice into such a major componant to do this, you could seriously mess your car up by doing this. so I belive that I am going to abort this mod and sell the dic with wire harness (plug with factory wires) and leave the analog in.
I know people are going to ask me do you even know if worked in the first place? and my answer is yes.All you need to do to see if the display works is get a 9volt battery and hook the orange and brown wire to the positve and the two black wires to the negative.If any body who reads this has done the mode please post what you did so you can help others.
Old 07-26-2007, 11:57 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
how much do you want for your digital display and wire harness?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
