Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-22-2007, 01:14 AM
77CapriceClassic 77CapriceClassic is offline
Question bout 77-90 Caprices
I have a 77 amd I am look for some new doors and seats. If I were to find a parts car in the year range of 77-90 would the doors fit on my 77? Say I found an 85 would those 4 doors fit on my 77?
1977 Caprice Classic - 350/350 Turbo Trans
Old 07-22-2007, 03:02 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Question bout 77-90 Caprices
No, the body style changed in 1980, the only doors that would fit yours are '77-'79. The cars are largely the same, but the '80-'90 is a little more rounded, with more hood 'slope', and less abrupt angles than the '77-'79 ones.
Interior parts are interchangeable, as are windshields and most windows, however the body panels are not.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-22-2007, 11:07 AM
Ahh ok thanks for the heads up. i know what youre talking about that bow that starts in the hood and goes through the doors into the trunk. do you think the seats would fit?
Old 07-22-2007, 12:23 PM
silicon212's Avatar
Confoundingly Lucid
Yes, the seats should fit.
Old 07-22-2007, 02:08 PM
mike561 mike561 is offline
if ever needed can you take doors from a buick lesabre, delta 88 or pontiac parreseine, would those fit onto a caprice as well? alot of those body styles look the same as well.
2006 Chevy Cobalt LS
Old 07-24-2007, 10:09 AM
Thanks for all the help! wish me luck
Old 07-24-2007, 11:08 AM
silicon212's Avatar
Confoundingly Lucid
Yes, any GM B- C- or D-body from the era will interchange the seats. This includes the Cadillac DeVille and Fleetwood.
Oh and 77CapriceClassic - Good luck and Godspeed!
Old 07-24-2007, 09:16 PM
1986Warthog's Avatar
1986Warthog 1986Warthog is offline
Send a message via MSN to 1986Warthog
I think (if you want new) this catalog may help: http://www.classicindustries.com they have a huge Impala/Full Size downloadable catalog... if they don't have the door skins, try: http://www.buy-oem-parts.com they have 'em for '85 Caprice's
Old 07-29-2007, 06:54 PM
Update:
Went looking through some junkyards just to see what they had and I found a 79 Impala and those doors looked a lot better shape than mine do. I saw the car on top of 3 or 4 other cars (they were stacked high) so I climbed up to inspect it and the drivers window is shattered but I could take the glass out of my old one for that and swap it in right? And I currently have electric doors and this one is a manual crank would it be possible to convert it to an electric window? What all needs to be done for this to become possible? Any suggestions, thanks in advance
Old 07-29-2007, 09:55 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Yes it can be done. I'm not sure what all needs to be done other than swapping out the motor and all electrical components for the door and any other parts associated with the power window setup. I swapped a power setup to a crank style door for my '76 Monte Carlo about 20 years ago. I ended up taking it to a bodyshop and was charged $25 back then for the labor,that was for the one door I had done and I had all the parts.
One other thing. Since you have the doors off the car and are in the process of replacing them, it would be a good time to check the hinges, especially the bushings and replace them before you install the other doors on the vehicle. It is easier to replace them now than having to take the door back off to do it in the near future if needed. I'm not sure how they will be on your 4 door vehicle as this is primarily a problem with 2 door cars, (which is pretty much all I owned back then.)The weight of the door causes the bushings, which are made of a soft metal, go bad and get sloppy. I ended up replacing many of the bushings and pins on my '70s to early '80s GM vehicles. Your vehicle may show signs of bushing failure given it' age and use over all of those years.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 07-31-2007, 09:25 AM
newkidontheblock newkidontheblock is offline
Does any one know where I can get a driver door and a passenger door for a 1980 2-door caprice classic that is not dented or rusted?
Old 07-31-2007, 10:47 AM
Check junkyards and craigslist, craigslist usually has parts cars for sale... at least they are some where im at. and junkyards are bound to have them
Old 04-23-2021, 03:59 PM
Dee504 Dee504 is offline
I was wondering if I could put a 1980 hood on a 78 caprice ? Or would a 78 Malibu/EL Camino
Old 01-29-2022, 03:52 PM
Collins74 Collins74 is offline
Hey I was trying see can a 85 Chevy Caprice front header panel fit on a 78 Chevy Caprice.?
