Old 07-19-2007, 02:53 PM
chevroletsilverado chevroletsilverado is offline
I need help!
. i need help sratchbuilding a 4-link rear suspension. does anyone know any websites where i can find reference pics?
chevroletsilverado
Old 07-19-2007, 04:49 PM
tigeraid's Avatar
tigeraid tigeraid is offline
Authorized Vendor
Re: I need help!
Do you mean a conventional parallel 4-link?
And with the panhard bar in the pic:
If you want a conventional splayed 4-link, it'll be any GM 64-88 GM A or B-Body, available in many model kits.
Old 07-19-2007, 06:10 PM
Re: I need help!
i was thinking of chevy stepside, plymouth duster
chevroletsilverado
Old 07-19-2007, 07:15 PM
Re: I need help!
these are some pics i was able to find.
plymouth duster:
http://cgi.ebay.com/ebaymotors/72-Du...QQcmdZViewItem
chevy stepside:
http://cgi.ebay.com/ebaymotors/1957-...QQcmdZViewItem
chevy stepside:
http://cgi.ebay.com/ebaymotors/ALL-S...QQcmdZViewItem
BTW i have an AMT plymouth duster and AMT chevy stepside that i was looking to try this setup on.
chevroletsilverado
Old 07-19-2007, 07:26 PM
tigeraid's Avatar
Authorized Vendor
Re: I need help!
Well except for different mounting points depending on the chassis, those are all essentially the same.
Old 07-19-2007, 07:53 PM
Re: I need help!
i'm new to scratchbuilding and wondering if you could give me some ideas.
chevroletsilverado
Old 07-19-2007, 08:47 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Re: I need help!
lets see here. For the rods I would do the following. Get some aluminum tubing of the propper size. Then get some hex rod of the same size. file/sand the hex so that it fits inside the tubing. Cut it off and file/sand flat to give you the jamb nut. Then drill out the center. Insert some plastic rod, then attach to the end of that a peice of plastic tube cut to width, that will give you the mounting point. If you weren't going for extreme realism you could skip the plastic tube and simply use some more plastic rod. the reason for going from aluminum to plastic is ease. I find it easier to glue plastic for strength than it is to glue aluminum for strength. If you wanted a simpler route. Start with the aluminum tubing. Then cut some SMALL pieces for the mounting eyes/heim joints. Then super glue them into place. that will give you a mounting point to slide between the brackets on the chassis and rear end mounts. feel free to e-mail me [email protected] for more help if you need it
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 07-20-2007, 11:53 AM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Re: I need help!
I'd grab a 'WagonRod' kit for the PU chassis and I know there has to be a prostreet mopar chassis around for the duster.
SCCA 7, The lost Z
