Old 07-16-2007, 09:26 AM
Kidego31 Kidego31 is offline
98 Voyager Blinking control lights
I got a 98 voyager and the rear wiper and a/c buttons are flashing...I disconnected the battery for a night and hooked it up and it still does it. I heard there is a way to "program" the control panel? Need help thanks
Old 07-16-2007, 09:31 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 98 Voyager Blinking control lights
Try one of these. Make sure the A/C is working first or the lights could flash till it's fixed: http://www.allpar.com/fix/codes-climate.html
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 07-19-2007, 12:33 AM
smurfcorpse smurfcorpse is offline
This happened to me once. My system was out of calibration. Here is the solution.. I hope
CALIBRATION/DIAGNOSTICS TEST ENTRY
TO INITIATE TESTS:
* Set Blower motor ON HIGH
* Set Mode position to Panel
* Open all A/C outlets
* Set Temperature to Cold (Both slide pots if equipped)
* Depress WASH and REAR WIPER button simultaneously for 5 Seconds (Until all LED's light)
RESULTS:
* All LED's will turn on for 5 Seconds
* Calibration Test is running when REAR WIPER and INTERMITTENT are alternately flashing. Cool-down test is running if A/C and RECIRC are alternately flashing.
* Acceptable result is REAR WIPER LED is the only LED flashing. Push Rear Wiper to exit.
Good Luck
Old 07-23-2007, 10:44 AM
IlmarsG IlmarsG is offline
Take a look also at http://www.automotiveforums.com/vbul...d.php?t=710504
