Old 07-08-2007, 05:28 PM
Ole_L Ole_L is offline
Double 2006 Honda RC211V
I decided to build these two bikes together. Most of the work will be identical on both up until individual colors and rider specific configurations. Both kits are fairly recent Tamiya releases. I'm using Tamiya's upgrade set for both bikes which include metal clutch and turned aluminum front forks. I may try a superdetailed version when TopStudio have their kit ready. For the Repsol bike, I will be using Zero paints which are great and very easy to airbrush.
Old 07-08-2007, 05:35 PM
stevenoble's Avatar
Re: Double 2006 Honda RC211V
Very nice start on the engines and frame parts.The wheel on the right is certainly colourful.You have my upmost respect building two kits back to back like this.I get a headache building just the one Keep the updates coming.
Steve Noble
Old 07-08-2007, 07:21 PM
Thanks... this is in addition to the other three kits I have on the bench.
The flourescent orange is Zero paint cleared with Refinished Select urethane clear (I'm still wating for the Zero 2K to arrive).
I realize I have the white balance on the camera set too high... will adjust next time around.
Old 07-08-2007, 09:24 PM
jmwallac's Avatar
jmwallac jmwallac is offline
Great start. I'm currently working on the '03 version of Max Biaggi. Fun build, isn't it?
Is your frame/swingarm kit chrome? Your engines look very cleanly built.
Recently completed projects:
Old 07-09-2007, 12:51 AM
ketje's Avatar
ketje ketje is offline
looking good for now.
Old 07-14-2007, 11:39 AM
Thanks... more updates soon. The chrome is kit chrome... I like the satin look.
Old 07-15-2007, 06:21 AM
I got the frame and swingarm pretty much completed. This is like a little factory with both bikes being at the same stage of the process. Next up will be the tank, fairings and tail which is in primer right now.
Old 07-17-2007, 07:21 PM
Both bikes are to a point where the swingarm is installed. I need to work on the front forks next, but the fender is needed, so I will finish them together with the fairings, tank and tail.
I used Zero Paint for the Repsol bike; it's great paint and very easy to airbrush, but dries flat and require a clearcoat. The LCR bike was painted using Tamiya laquer. I will let the decals dry for a few days and then clear.
Old 07-17-2007, 09:21 PM
jmwallac's Avatar
Good decal work! That LCR livery is catchy IMO.
Old 07-17-2007, 11:11 PM
ketje's Avatar
looking great. What about the decals used on the zero paint? Did you mist the bodywork with the clear before putting them on?
Old 07-18-2007, 05:12 AM
stevenoble's Avatar
I'd like to know the same thing as well and how difficult were the decals to apply on the Repsol bike? It's certainly one I fancy building myself but the decals and colour scheme always put me off.Is it hard to do?
Steve Noble
Old 07-18-2007, 10:31 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Superb stuff
Steve a.k.a. Hiroboy
Old 07-18-2007, 10:50 AM
The Sheene Machine's Avatar
The Sheene Machine The Sheene Machine is offline
Really nice work Ole - I have the LCR kit myself which I'm keen to do. Your biuld will serve up some pointers for me I'm sure. One question - re the Repsol bike; do the decals lay over the blue or orange on the front part of the fairing, or in other words, any bleed through??
Paul
On the bench;
2003 LV Rossi Honda RC211V
Old 07-18-2007, 12:48 PM
Thanks for the comments.... the decals themselves are really easy to apply. Cartograf makes the best decals out there. As for clearing, I'd normally do it due to the flat surface, but seeing Steve (Hiroboy) apply the decals straight on the flat surface, I went ahead and did the same and they seem to adhere well. I will let them dry for a few days and give the Zero 2K clear a try.
Again, with the Cartograf decals, you have real great quality, and there is no bleeding at all, just make sure you don't have a seam from masking off between the colors. I painted and masked according to the instructions which was really a minimum amount of masking. A little bit on the front part of the fairing and some on the sides, that's all, the rest are single color paint and just decals.
Old 07-22-2007, 07:18 AM
kanedge kanedge is offline
Nice start. How were the decals on the LCR bike, easy or difficult?
Look forward to more.
