Old 07-08-2007, 05:39 PM
appleseed's Avatar
appleseed appleseed is offline
350z
I couldn't get myself to throw this one away. This kit was painted over 4 times, finished once and destroyed again. One of the front A-pillars were broken as well as the front bumper beyond repair.
Half of the front bumper has been cut off and re-created. Armed with my trusty plastic card and putty, I began to just throw things on and let it take shpae gradually.
The front end looks to have a fairly good profile/shape thus far- I'll probably leave it alone until the first shots of primer. The fender flares are halfway done as I don't want to finish off the bottom portion of it yet until I figure out what to do with the sideskirts.
I envision the rear end to have blister flares blended into the body. Won't know how that will turn out until I start working on it.
As always, this is going to be one long build
a.
Old 07-08-2007, 05:49 PM
voyageur voyageur is offline
Re: 350z
WOW!!!
I'm really looking forward how this is going to turn out.
Keep it coming!
Old 07-08-2007, 06:21 PM
jmwallac's Avatar
jmwallac jmwallac is offline
Re: 350z
Those flares look great. Keep it up!
Recently completed projects:
Old 07-09-2007, 12:54 AM
Jaymes's Avatar
Jaymes Jaymes is offline
Re: 350z
your body work always looks so clean...what kind of putty do you use?
Old 07-09-2007, 01:53 AM
appleseed's Avatar
Re: 350z
Believe it or not, I ran out of the putty that I normally use and just tried somethig local from the hardware store... Bondo. I can honestly say that I will only use this until I run out of it. I'll probably not use it again. It does not stick well to the plastic nor does it feather well... but it was easy to get my hand on. Hopefully I can finish this build with this without any problems with the putty.
a.
Old 07-09-2007, 10:37 AM
jmwallac's Avatar
Re: 350z
Is this the red stuff in a metal tube? I got some from Wal Mart and noticed it tends to melt the plastic if it's applied too thickly.
Old 07-11-2007, 12:38 AM
Gaoza's Avatar
Gaoza Gaoza is offline
Re: 350z
It's looking great so far. Very clean! I can't wait to see this finished
Old 07-11-2007, 04:25 PM
rsxse240 rsxse240 is offline
Re: 350z
it appears to me that it is the traditional 2 part bondo, and it looks like it could have used just a bit more hardener (I usually mix mine so it is a bit more tan, so it dries faster)
Old 07-12-2007, 07:06 PM
BigDaddy1569's Avatar
BigDaddy1569 BigDaddy1569 is offline
Re: 350z
That stuff in the metal tubes is called red lead. Its for fine scratches after you bondo and sand your car. Dries quick and sands easy. Later,Q
Old 07-14-2007, 05:58 PM
Fabbri_Guy's Avatar
Fabbri_Guy Fabbri_Guy is offline
One Off model builder.
Re: 350z
cool wide front end, although it looks funny without the rear widened. Cant wait to see progress on this. I've always thought about using Bondo, anyways keep up the great work.
Old 07-22-2007, 04:00 PM
appleseed's Avatar
Re: 350z
Quickie update:
a.
Old 07-22-2007, 04:44 PM
Gaoza's Avatar
Re: 350z
wowww, very very clean. I like!
Old 07-22-2007, 05:44 PM
energon's Avatar
energon energon is offline
Re: 350z
Looking GOOOOOOD!!
click me ^
My Deviant Art
Old 07-23-2007, 01:56 AM
Fabbri_Guy's Avatar
Re: 350z
Is that Bondo easy to work with? Cause you make it look like it is. Very clean widebody looks good!
building rides since 2000.
Old 07-23-2007, 03:04 AM
Jaymes's Avatar
Re: 350z
Wow you are really good with putty and scratchbuilding. Lookin good so far
