Go Back   Automotive Forums Car Chat > Buick > Regal
Old 07-05-2007, 05:41 PM
alum4065 alum4065 is offline
TSP Bucik Regal 1995
What should the TSP reading be for a 1995 Buick Regal 3800?
Thanks-
Old 07-05-2007, 07:02 PM
maxwedge maxwedge is offline
A990 racer
Re: TSP Bucik Regal 1995
Welcome to AF, what is the "tsp" do you mean tps?
Old 07-06-2007, 08:01 AM
Yes- I mean Throttle Position Sensor.
Old 07-06-2007, 08:10 AM
BNaylor's Avatar
BNaylor BNaylor is offline
The TPS output to the ECU module will typically read around .4 volts at idle to 4.5 volts at wide open throttle (WOT). Linear and progressive readings from idle to WOT while slowly moving the accelerator. No bad/flat spots or out of range reading. Reference voltage at the input around 5 volts.
Timeslip 08/12/06
AF Community Guidelines
Old 07-06-2007, 10:20 AM
Thank you very much bnaylor.
