Old 11-01-2002, 10:43 PM
strodda strodda is offline
What else creates interference?
i know the huge deal about not running the 12v and rca close to eachother. but i have them going down opposite sides of the car. what else can create engine noise in the line?
Old 11-01-2002, 11:42 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
bad spark plugs
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 11-02-2002, 12:59 AM
well i have newish plugs and wires. anything else that might have to do with the actual install?
thanx
Old 11-02-2002, 08:33 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
running the power wire and RCA's on opposite sides has NOTHING to do with it - as you have already found out. The problem is either that you have your RCA's run near the ground point of a noisy device or you have a weak ground somewhere. Try using UTP (unsheilded twisted pair) for you RCA's - they don't pick up noise nearly as bad as normal type.
Old 11-02-2002, 01:27 PM
delsolsi delsolsi is offline
A fried alternator can cause this also.
Old 11-02-2002, 02:24 PM
Originally posted by delsolsi
hey, go join North West Honda
I know you don't have a honda, but you're in a honda forum right now. There's lots of cool people there, some of them don't have hondas either, but they have cool meets and stuff.
2000 BMW 323IT
1954 Ford F100
Old 11-02-2002, 11:32 PM
thanks guys, i basically got that squared away. i got rid of the popping by running separate rca's and grounds.
one more thing. when i turned the HU on, one of my amps protection light went on(as it does when its first turned on), but instead of it going out and the green light coming on... the red light just turns off, and nothing happens. it only happened once though. i just want to know what i can check so it doesnt happen again. btw, all the ground are good and tight, and the fuses arent blown.
Old 11-03-2002, 04:30 PM
Audio Guy
the red light comes on and STAYS on when the amp detects something wrong like shorts or overheating. You probably had a strand or two of speaker wire that was shorting out at the terminals and when you went to check the amp out you pushed them back.
Old 11-03-2002, 05:34 PM
shit!
well both amps seem to be working fine, but that popping came back. when i listen close to the subs, the boom sounds solid sometimes. but every once in a while, the bass hits and it starts to sound hollow, and a little like something is rattling inside... but then it goes away. im stumped.
Old 11-04-2002, 06:29 PM
Audio Guy
is the only the bass amp you are having troubles with ? are the bass speakers in a sealed or ported box ? do you like to listen to bass with lots of low frequencies ?
Old 11-04-2002, 09:49 PM
theyre in a sealed box. and actually i think both amps are being affected. when i hear distortion in the subs(powered by the lanzar), sometimes the sony amp goes out too. and even when the sony amp has gone into offset mode, i still hear popping from the subs.
right now i have a single rca w/a y-adaptor to split it to both amps. i still dont know whats wrong, but in a week or so when i get my new subs, im going to put a cap in and run separate rca's from the HU
PaulD: if you get a chance here's a sound clip of what the poppping is doing. subs_popping
if there was anything wrong with the sub amp, would the protection light always go on?
Old 11-05-2002, 08:45 PM
Audio Guy
I tried listening to it already ... couldn't make heads or tails out of it. I just have two little speakers on my computer. I can't really say for sure without hearing it and seeing it. And maybe not even then .... hard to say. If the protection light stays on, you definitely have a problem. It should stay on as long as something is wrong, when you remove the problem - the light will go out.
Old 11-06-2002, 12:08 AM
yea, thats what i thought. when the distortion comes through, the sony amp shuts off as expected. but eventhough the subs are popping, the sub amp ever seems to be affected. it hasnt gone into protection once.
GM 2.2L OHV DOHC: Interference or NON-Interference sharpnshine General Discussions 1 04-27-2009 07:21 PM
What is creating this noise in my 403 cmilliron General Discussion 0 04-20-2003 05:31 PM
1988 Accord DX - what engine could I put in it? What else could I do? Mr. Tapeworm Accord/TSX/Accord Hybrid 2 01-20-2003 02:55 AM
what else do you do... VTECelude COMPLETELY off-topic 18 04-03-2001 09:48 AM
