Old 06-27-2007, 09:16 PM
tmyate01 tmyate01 is offline
Reverse lights not working...
I have a 2001 Alero 5sp and the reverse (backup) lights are not working. I've also recently noticed I no longer have to put my car in reverse to remove the key from the ignition. I've checked the fuses (even under the hood) and they all seem to be fine. Anyone have any ideas on this?
Old 06-28-2007, 06:32 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Reverse lights not working...
Hopefully you checked or replaced the backup lamps first.
Timeslip 08/12/06
AF Community Guidelines
Old 06-28-2007, 02:00 PM
"Hopefully you checked or replaced the backup lamps first."
Yes I did. Any other ideas?
Old 06-29-2007, 07:02 AM
BNaylor's Avatar
Not sure about Aleros with the manual 5 speed but the automatics have a switch called a transmission range switch. The manual should have a similar switch for reverse detection which also turns on the backup lamps so check the transmission for that type of electrical component. Maybe the connector is loose. Also, the switch may be located at the shifter assembly at the center console.
Timeslip 08/12/06
Old 06-30-2007, 10:42 PM
vamc's Avatar
vamc vamc is offline
bad relay or fuse?
