Go Back   Automotive Forums Car Chat > Buick > Century
Old 06-25-2007, 07:50 PM
gypsum gypsum is offline
Red face 2005 Buick Century A/C Discharge warm left cool right
When using A/C driver side discharge temperature noticeably warmer than passenger side. Buick's service manager's estimates the cost will be over $400 too fix. I'm looking for a second opinion
Old 06-26-2007, 12:17 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2005 Buick Century A/C Discharge warm left cool right
Welcome to AF.
On single and dual zone manual climate control systems start with checking the refrigerant charge at the low side port. May just be low or you have a leak. It will cause uneven cooling across the evaporator affecting the driver side cooling. In a worse case if the charge is good then the driver's side temperature actuator located in the dash is not working properly.
Timeslip 08/12/06
AF Community Guidelines
Old 06-26-2007, 12:30 PM
Low refridgerant is the likely cause. Thank you bnaylor.
