Old 06-19-2007, 01:50 PM
chuck0 chuck0 is offline
Question Temperature Gage gone crazy-3.8L
I have (2) problems:
1). My temp gage needle fluctuates between normal and max. hot positions along with the gages red light coming on, both randomly. Coolant level is o.k. and the engine doesn't seem to be overheating.
2). However, the engine has started to misfire consistantly.
Is the coolant sensor no good and does it somehow send a faulty signal to the computer causing the engine to misfire? Or are these problems unrelated?
Old 06-19-2007, 10:24 PM
Re: Temperature Gage gone crazy-3.8L
Follow-up:
I removed the "appearance cover" from the engine and found (2) bare wires (1) grn and (1) yellow going into a connector that had (1) blk, (1) grn and (1) yellow wire. They were located straight back behind the oil filler tube in front of the fuel rail. I insulated each wire with tape, started the engine and all the problems were gone.
My question now is: Are there connectors available with wires that I can splice into what remains of the grn and yellow wires?
Old 06-19-2007, 10:32 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
So did that fix your crazy coolant readings problem AND your misfiring? Or just the misfiring? Or just the coolant readings?
If I understand your post correctly, the wires are still disconnected from where they are intended to go, and you have them taped up so as not to short out. Youre wanting a new connector to fix things up?
Im not entirely sure what youre wanting, the connectors themselves may be troublesome to find, and may be a dealer only thing $$$$. you can probably fix up what youve got. But im curious to see what wiring is unattached, I dont have a 3.8, and its been a while since Ive messed with one. Got pics?
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 06-20-2007, 06:45 AM
Misfiring & temp gage reading problems were gone as a result of taping (insulating) the wires. These wires ran next to each other andwere always connected to the connector. I only insulated them from each other. I was hoping there would be replacement connectors(with wire leads) available that I could splice into the harness and replace the tape fix that I did.
Old 06-20-2007, 06:53 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Based on your description it sounds like the connector and wiring to the EGR valve. The GM electrical connectors do not come with wire leads, connector only. The EGR wiring is part of the main engine compartment wiring harness bundle. One option is to use heat shrink insulation instead of replacing the connector and damaged wiring.
Timeslip 08/12/06
AF Community Guidelines
