Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-18-2007, 06:25 PM
704ChevyBoi 704ChevyBoi is offline
Carburetor issues or What?
ok here's my problem...... about ten minutes after my 87 warms and I'm crusin along, all of a sudden every time that I press down on the brakes to stop the engine shakes badly and sometimes even shuts off when I press down too fast but (like a chevy) it always starts right back up, this is becoming a real headache cause i've been to 3 different mechanics and they never fix it just other stuff like,
>New Hoses
>Spark plugs and wires
>Adjusting the Carb.
>New Battery
My Buddy says for me to just get a new Carb. but before I go off and spend that kind of $ I wanted advice from some real experts, I'm at the end of my rope..........HELP PLS!
Old 06-18-2007, 06:50 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Carburetor issues or What?
None of the above.
Replace your Power Brake Booster.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-18-2007, 06:54 PM
joe68 joe68 is offline
totally agree!
1965 ss conver chevelle "red
1964 ss impala "red"
1964 bisq. gold 4 doors
current 1968 chevelle
" all apart at the moment"
Old 06-18-2007, 07:30 PM
Blue Bowtie's Avatar
Registered Offender
If you doubt that diagnosis, remove the vacuum hose from the power brake booster and cap/plug it. Step on the brake pedal all day long and see if the engine stumbles. If you can currently get the engine to do the stalling while just sitting at idle, you can test the theory without even moving.
Remember that if you drive it in this manner, the brakes will operate just fine, but will require a lot higher pedal effort to stop the vehicle.
Old 06-21-2007, 06:01 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Or very temporarily clamp a pair of flat-jaw vise grips on the hose and check it out. This is best done in the driveway.
Bob
Old 06-23-2007, 08:00 PM
ok thanks, About how much would a mechanic charge me to fix or replace my power brake booster
Old 06-23-2007, 08:07 PM
GreyGoose006 GreyGoose006 is offline
it could also be the tcc solenoid, but that is unlikely.
Old 06-23-2007, 10:48 PM
silicon212's Avatar
Confoundingly Lucid
Not likely as this will cause an engine to simply want to "shut off" when the car gets close to stopping, and it will make braking the car more difficult.
His issue is when he presses the brake, which to me reveals a leaking diaphragm in the booster assembly. Press the brake - huge vacuum leak.
