Old 06-10-2007, 07:32 PM
intentium intentium is offline
turbo charging
if i put two turbos together that put out 15 psi each, do i end up with 30 psi boost?
Old 06-10-2007, 09:15 PM
INF3RN0666 INF3RN0666 is offline
Re: turbo charging
Almost 30 PSI but not exactly...You have to account for resistance when you combine the two. Besides, having two turbo chargers on your exhaust system, they probably won't reach 15 PSI boost each anyways. But if they do reach 15 PSI each, they would make ALMOST 30 PSI combined.
UncleBob UncleBob is offline
AF -Advisor
Re: turbo charging
depends how the turbo's are routed. In parallel (most common config) it would be 15 psi. In series, it would atmospheric ratios mulitplied, IE, 15psi at sea level = 2.0. 2.0 * 2.0 = 4.0 * 14.7 = 58.8psi
there is no configuration that is straight addition. IE, 15psi + 15psi = 30psi
if you had 16 turbo's in parallel, and they were all set at 10psi. The total psi would be 10psi. Not 160psi
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 06-10-2007, 11:52 PM
Re: turbo charging
so what are the pros and cons of single turbos compared to twin, i would really like to in the future put twin turbos on a car and am trying to learn more about them
Old 06-10-2007, 11:53 PM
AF -Advisor
Re: turbo charging
for gas engines, you're talking parallel. There is no performance advantage to 1, 2, 3, 4, 8 etc turbo's. Single turbos have a tiny advantage in efficiency. The only advantage to twin turbo's in this situation would be spacing issues such as tight engine compartments for a V-bank engine config
if you got the room, go with a single.
Old 06-11-2007, 01:31 AM
KiwiBacon KiwiBacon is offline
Re: turbo charging
You forgot to convert absolute pressure back to gauge pressure.
Take 14.7psi off that 58.8, gives you about 35 psi boost.
Old 06-11-2007, 01:33 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: turbo charging
Twin turbos (which is parallel routing) will provide you with additional flow volume but the same pressure. Let's say you need 400 cfms of flow in a V8 engine. You can get that with a single large 400 cfm turbo set to provide 10 psi. If you want, you could run two smaller 200 cfm turbos. That would retain the 10 psi, but the smaller turbos have the main benefit of a smaller mass to accelerate. Lag is decreased. You also can benefit with simpler plumbing in a V8 application not having to route exhaust gasses to one side.
Compound turbos (series routing) are kings in peak pressure and really shine with diesel applications where pressure is king. They take the air from the first turbo and pressurize it again. If you double the boost ratio in both turbos, you quadruple it in total. If you triple it, you multiply by 9 at the end. Some diesels with compounds are running nearly 150 psi intake pressure.
Dragging people kicking and screaming into the enlightenment.
Old 06-11-2007, 03:55 AM
madan80 madan80 is offline
Re: turbo charging
Going further - What if you have a twin Carb - The twin turbo can feed each carb - how would you calculate boost for that?
Old 06-11-2007, 04:16 AM
AF -Advisor
Re: turbo charging
one of my turbo'd bikes has four seperate carbs. I figure I'm pushing at least 600 psi due to that alone!
Old 06-11-2007, 04:20 AM
AF -Advisor
Re: turbo charging
the important point is, gas engines you never get over 40psi. Very very rarely anyway. Otherwise detonation becomes a very serious issue. That is why turbo's in series is nearly non-existant in gas engine applications
Turbo's in parallel are straight forward (regardless to the number of carbs or TB's) 10 psi = 10 psi regardless to the number of turbo's
Old 06-11-2007, 09:27 PM
Re: turbo charging
you guys have been a big help, thanks a bunch for all the good info
Old 06-11-2007, 09:45 PM
Re: turbo charging
Think about having a dual forced induction system. Super charger gives you boost at low RPM, turbo charger gives you much more boost at high RPM. Why spend money on two turbos if the people above me said they won't be very effective anyways.
Old 06-11-2007, 10:22 PM
AF -Advisor
Re: turbo charging
there's also sequential turbo's, like the RX7's did for a little while, but that is a overly-complex way of solving the low RPM/high RPM issues.
Two turbo's, one is very small and boosts very early, the other is large and boosts late. Through multiple flapper valves in the exhaust and intake, it flows everything through the small turbo at low RPM's, then switches to the bigger turbo at higher RPM's.
VW has come out recently with a simular setup using a supercharger and a turbo.
I like to keep things simple. A variable vane turbo is a better answer to the issue IMO than sequential. Or just size a single turbo reasonably. You won't get the bragging-rights with huge HP numbers, but it'll be the funnest to drive
Old 06-12-2007, 12:34 AM
GreyGoose006 GreyGoose006 is offline
Re: turbo charging
er, most fun that is.
jk
personally, i would prefer a twin turbo setup for the simple fact that you can use smaller turbos and get away with less room in the engine compartment.
although a single large turbo is probably more efficient in absolute terms.
Old 06-12-2007, 01:05 AM
AF -Advisor
Re: turbo charging
the difference between single and twin parallel is so tiny its not even worth mentioning, as far as spool/efficiency.
The only puprose going to twin's, is space issues. (and the imaginary bragging rights, which is only good for ignorant people, of course)
