Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 06-10-2007, 03:43 PM
vramamu vramamu is offline
whistling sound
I have a 97 honda Civic LX 4dr, its giving out the whistling sound from the windshield when going at highway speeds.
I have searched and searched..for this topic, its there every where but no concrete solution..
the sound is quite high and driving me crazy!!
I am ready to do anything !!! plz help
any help is really appreciated..
thanks
VR
Old 06-10-2007, 05:15 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: whistling sound
Maybe you're missing a weather seal somewhere. Look around the door jams and windshield for missing rubber.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 06-29-2007, 07:09 PM
carbomb916 carbomb916 is offline
Re: whistling sound
I had this issue. I had to get a new window motor because it wasnt pushing the window all the way into the rubber seal. See if you can zero in on the culprit. Have someone sit in the car while your flying down the highway. Or pump the radio up and ride!
Old 07-01-2007, 09:53 AM
alfonso2501 alfonso2501 is offline
Send a message via AIM to alfonso2501
Re: whistling sound
Look at the weather-stripping around the windshield. Is it loose anywhere, or is there any rot or buckling on it?
Old 11-24-2007, 11:51 AM
PeteNC30 PeteNC30 is offline
Re: whistling sound
Hi VR
I'm a newbie on here and was just about to post a thread about a problem with my driver's side, (UK R/H side), door glass that may be the same as your problem. I started to notice a whistling / wind rush sound when travelling at speed which has gradually got worse. When I eventually got around to checking out all the seals etc I noticed that the top corner of the driver's door glass was sitting on the outside of the door seal. The problem has now reached the point where, if you don't push on the outside of the glass as you raise it, the top of the glass will sit completely on the outside of the seal from about half-way up the window aperture. The glass raises squarely, (horizontally), but seems completely askew virtically. Before I just start pulling the door apart I just wondered if anyone else has had this problem and if so what's the remedy please. Thanks.
Pete.
