Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 06-04-2007, 04:52 PM
markcoc markcoc is offline
1989 chevy beretta code 43
I have 1989 beretta with check engine light on , reads code 43.I have changed knock sensor, and ignition module, but light is still on .I need help!
Old 06-05-2007, 06:38 AM
Blue Bowtie's Avatar
Registered Offender
Re: 1989 chevy beretta code 43
I believe your '89 still used the separate ESC module. Verify all connections, especially the ground for the new sensor. You can also install a 3.9K ohm resistor in place of the sensor to determine if there is actually noise being detected by the sensor.
After clearing the codes, determine how long the engine will run before the code sets again.
