Old 10-25-2002, 09:03 PM
sausage sausage is offline
Large pin vise?
I'm currently drilling 3-4 mm holes for headlights. My pin vise, and I think most others, can only hold bits up to 2.5 mm. Are there any larger ones around?
In addition, where can I find 3-4 mm clear headlight lenses? Sakatsu's convex lenses are a bit larger than that.
Recent stuff:
Singapore scale modeling site at http://machinemess.singaporeanimenews.net
Old 10-25-2002, 10:34 PM
freakray freakray is offline
AF Modelrater
Sausage,
There are larger sizes available, but I don't know where I would recommend for you to find one in Singapore.
We used to use them to hand ream holes in the tooling industry, they could hold up to 8mm shanks(the part of the drill you hold) in a 3-jaw chuck, so I am sure it will work for you.
I would imagine you could try looking at engineering supply stores or even well-stocked hardware stores, maybe you could contact a local machine/engineering workshop to see if they can point you where to get one.
Either way, they are available.
Ray
AF User Guidelines
Old 10-26-2002, 07:47 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
or you could buy a Dremel, which is much better than a pin vice.
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
