Old 06-01-2007, 07:50 PM
silverado_76 silverado_76 is offline
Low and Mid hp
I have a 2002 Silverado with a 4.8L V8 engine and after removing my catilytic converters and putting just straight pipes I noticed a HUGE increase in top end power. But my low and midrange hp seems less or the same. I was just wondering if there was any affordable aftermarket products that could help me in the bottem end. I bought a superchips flashpak tuner and it helps, but it still seems a little sluggish.
Old 06-01-2007, 07:55 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: Low and Mid hp
the reason you didn't find any change in the low and mid ranges is because your cat wasn't causing much backpressure there. it was only causing restriction at higer rpm, so you only get a difference there when you remove it.
depends what you mean by affordable, what's you budget?
you could get a new cold air intake and filter for ~$140, new exhaust for ~$250 and together you'd get maybe 15hp gain.
after the basics (intake, exhaust, chip) it gets a little more expensive.
Seatbelts Saved My Life
Old 06-01-2007, 11:17 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Low and Mid hp
572" rat motor transplant would help a bit
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 06-02-2007, 06:33 PM
GreyGoose006 GreyGoose006 is offline
Re: Low and Mid hp
then twin turbo it
Old 06-02-2007, 09:45 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Low and Mid hp
A good set of small tube headers will help. Going big would help high rpm power more at the expense of low end torque. Get a good set of small tube headers and you'll be rewarded all over the board.
Dragging people kicking and screaming into the enlightenment.
Old 06-03-2007, 11:07 PM
AF -Advisor
Re: Low and Mid hp
Originally Posted by GreyGoose006
then twin turbo it
I like the way you think
