Old 05-31-2007, 02:06 AM
JoeTex JoeTex is offline
Need Help Dash Light's Gone Out
I OWN A 2002 DODGE CARAVAN SPORT..I LOST ALL THE DASH BOARD LIGHT EXCAPT THE RADIO'S..I CHECKED THE OWNER'S MANUAL..AND I CANT SEEM TO FIND THE RELAY OR A FUSE LEADING TO IT..ALSO A LITTLE BEFORE THAT THE AIR CONDITION LOST THE REST OF THE SPEEDS AND I JUST HAVE HIGH...ANY ADVICE..
Old 05-31-2007, 08:18 PM
Thanbor Thanbor is offline
Re: Need Help Dash Light's Gone Out
Be sure the dash dimmer isnt all the way off. If it isnt the fuse, that might be it - especially if you have kids that like to "play with the knobs".
Old 06-01-2007, 09:39 PM
No Its Not That I Triple Checked That Before I Posted This Forum..i Suspect Its A Fuse Or A Relay But The Thing Is That I Cant Seem To Find Them...
Old 06-03-2007, 05:55 AM
vipergg vipergg is offline
Find the IOD fuse under the hood in the fuse center and pull for a couple of minutes , sometimes the bcm will get confused and this resets the bcm , you will lose all radio presets doing this .... For the fan problem , replace the blower resistor behind the glovebox ... If you have a cabin filter make sure to check that is clean and not clogged up as this is what can burn out the resistor . Filter located under the dash on the passenger side. Not all models have this so you would have to look .
Old 06-03-2007, 08:03 AM
hey Thnx Partner..i'll Take A Peek At That This Morning...i'll Get Back...
Old 06-07-2007, 07:31 AM
yea it shure was that iod fuse the one causing the prob..i just now need to get to the motor of the air cond...thnx patrner
Old 10-31-2007, 04:18 AM
Krazy Jeff's Avatar
Krazy Jeff Krazy Jeff is offline
When pulling the IOD fuse are we suppose to first disconnect the ground cable from the battery, or is it harmless to do it with the battery connected?
Old 10-31-2007, 09:50 PM
No you don't have to pull the ground , that would do basically the same thing as pulling the iod fuse , pulling the fuse is easier than messing with the ground cable.
Old 11-01-2007, 01:30 AM
well i dont recall have'n disconnected the batterey when i reset that fuse,,but the prob has long been solved and the lights have not gone out since vippergg suggested me to remove the fuse,,but thanx for your concern,,but the only problem that i have not gotton to is the mottor that controls the air cond's speeds
Old 11-01-2007, 02:21 AM
Krazy Jeff's Avatar
Hi Joe Tex,
I am not sure if you have seen this marvelous tutorial and troubleshoot procedure in fixing the AC blower, but if you follow the instructions you might find the issue and fix it yourself. Here is the link: http://www.automotiveforums.com/vbul...d.php?t=340871
That is the reason how I found this wonderful forum. Since I am also having an issue with the blower just turning on when it wants. I bought the blower relay for about 3 bucks (would haven been 17 bucks if I would have bought it at the shop), and then I picked it up today at my local Kragen. (Did make the guy at Kragen double-check that was the blower-relay I needed--I did discover that many relays in the Voyager almost use the same relay, so there really isn't a unique motor relay, it all is based on the function that particular relay does--but don't quote me on that--still learning.)
I plan to install the relay tomorrow, since by the time I picked up today it was getting dark. Can't wait to see if it fixes my issue, but if it does, I plan to reply in that wonderful tutorial and give my respects to the tutor professor there! Wish me luck.
Thanks for the reply viperegg. Could you do me a favor? Could you go to this thread I started here: http://www.automotiveforums.com/vbul...d.php?t=762346 and tell me where to locate that IOD fuse on my Fuse & Relay Center which I provided the picture of it there? Thanks a million!
Old 11-03-2007, 01:46 AM
Well thats a new one to me i was never told the blower motor had a blower motor relay ,,and about the iod fuse well i see that your mini vans fuse box is diffrent then mine so cant help you on that..but in my late timing i see vippergg has already gotton to your problem..so in all goood luck
Old 11-03-2007, 02:03 PM
Leaf Blower Leaf Blower is offline
I have a 99 T&C, The dash light went the other night, checked the fuses and they were ok. Pulled the light switch out of the dash and found that the dash lights part of the switch was history. Today I replaced the light switch, and checked the dash light light bulbs are ok but they still won't work. I removed the IOD fuse for about 30 sec. and retried the lights still no luck. All of the other lights work.
Old 11-03-2007, 02:12 PM
wafrederick wafrederick is offline
Banned
Probaly needs the Body control module replaced,it is probally bad,a very common problem.You have to take to the dealer to get programed with Chrysler's factory scan tool DRB III.
Old 11-06-2007, 03:15 AM
welll that sounds like a diffrent problem...i think the iod fuse is for the neon type dash lights only..cause i use to own a 1997 town&country lxi and it was not like the 2002's fuse box(caravan sport)
