Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-30-2007, 12:58 PM
BostonKev BostonKev is offline
2000 CVPI wiper motor question
Hi All, just bought this one and I find that the wipers intermittently fail to immediately engage and start working. I removed the multifunction switch and cleaned all the connections and sometimes when I turn on the wipers I need to wait about 30 seconds for them to actually come on. Once on, they work fine. I assume this is the motor itself but figured I'd check before I grab one at a bone yard. Thank you
Old 05-31-2007, 08:42 AM
JoeTex JoeTex is offline
Re: 2000 CVPI wiper motor question
Hey Partner I Also Own A 2,000 Cvpi,,and A Little After 2 Yrs Ago We Had A Light Freeze Here And Texas And The Wipers Statred Failing Somthing Like Your Discribing..but Insted Mine Dont Stop Completly..they Stay Half Way.we Dont Really Get That Mutch Of Rain In This Part Of Texas So Its No Big Deal..but If You Do Have That Problem Use Rain X
Old 05-31-2007, 07:43 PM
Have you ever run into anything like this W2O? Possible voltage issue maybe?
Old 06-03-2007, 07:15 AM
well No I Have Not Checked Into That But I Suspect They Just Need Some Wd-40 Or Grease On Em''but Since Boston's Kev 2000 Cvpi Has The Same Prob As My 2,000 Cvpi I Think It Must Be Some Factory Defect..
Old 06-03-2007, 06:57 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Hey Kev. Check the wiper delay module also. If it is hesitating before start up could be the module. To be sure, check for voltage at the motor. Should have voltage as soon as it is turned on. Good to hear from you again.
JoeTex--If the wipers stop in the upright position, the park circuit os out of the motor. Easiest fix is to replace motor.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-04-2007, 10:15 AM
I'll probably just toss a new motor in as it doesn't look like a huge project. It just kills me that sometimes it works perfectly and other times when you turn the wipers on you have to wait about 25 seconds for them to come on and then they work fine. Oh well.
Old 06-06-2007, 05:56 AM
way2old's Avatar
TOKEN HILLBILLY
Hey Kev. Ford has a TSB on the wiper motor for intermittent operation or turning themselves on. So the motor and pigtail may cure your problem.
Old 06-07-2007, 06:47 AM
oh thnx way too old..where would i find the wiper motor?do i need to take off the whole plate holding the wipers??
