Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 05-25-2007, 01:44 PM
TLEC TLEC is offline
What Language does a 92-3.8 speak
I would like to know what language the PCM and ABS speaks, is it ODB1 or ODB2, Is there any lists of codes avaible anywhere.
Old 05-25-2007, 01:51 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: What Language does a 92-3.8 speak
OBD I . Here is a link I have found useful in the past that can give you some more info:http://www.geocities.com/dann8785/se...nginesoon.html
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 05-25-2007, 01:59 PM
Ok then, is there any description on the various codes to read and to send.
Reading the workshop manual, there seems to be possible to get live data as well.
Old 05-30-2007, 10:45 AM
LMP's Avatar
LMP LMP is offline
Check this out:
www.avigex.ca/xport/readingcodes.jpg and www.avigex.ca/xport/3800codes.jpg
Then check this www.avigex.ca/xport/index.doc for a lot of pages most of them scanned from the '93 transport manual; one difference with the '92: yours probably does not have an EGR valve.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 05-30-2007, 11:02 AM
Ok, got that, but what I really want to do is to tap into the serial line, otherwise I cant get the ABS-codes nor do the various tests, I guess.
Old 05-31-2007, 05:02 PM
nicke66 nicke66 is offline
There once was a very talented german guy, Manfred, who wrote software to comunicate with the control modules in the Trans Sport. The 3.8 PCM and the ABS module speaks ALDL 8192 baud, with a certain protocol.
You can easely build yourself an interface to connect a PC to the PCM, and run Manfred´s software (most of it is in english!)
Check this site for interface drawing and software:
http://www.pontiac-interface.de/
Use Manfred´s software running DOS and not the new stuff "TS-Diag" that is not ready yet.
