Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-24-2002, 11:57 AM
kungfujap kungfujap is offline
clutch, cam, valvetrain, blower: help!
I have a 99 ex with CAI, full exaust, eldelbrock header, random cat the whole bit. Im doing my drive train now to prep for the supercharger. Im thinking about getting an ACT clutch which comes with the organic street disc and the xtream pressure plate. It has plenty of holding compasity cause i don't plan on running over 8 lbs of boost. Oh and I plan on getting their new 8.9 lb cromoly flywheel with it. Ive looked into clutch and flywheel packages alot and this package seemed like a wise choice. What do you guys think? Suggestions? Oh and one more question. Im looking into getting a cranecams stage one cam with the titanium valve train components since my stock cam isn't really aggressive enough reap too many benefits from my current bolt ons. I talked to crane and they told me that the grind i wanted would compliment by supercharger, which i plan on purchasing along with a 68mm throttle body. Since money is tight with me do you think I should throw the blower in first, then save for the cam, valve train and throttlebody; or do it the opposite way and get the blower last? Thanx for the help
Old 11-07-2002, 08:49 AM
hondatool hondatool is offline
id say get the blower first cuz your stock engine is gonna be able to handle the 6 pounds of boost it puts out fine, then i would go with the valvetrain but definately upgrade your clutch, i think the most the s/c puts out is 6psi depending on the s/c, the ex engine should handle that safely....i have a EX too and run 8 pounds of boost from my turbo, it runs perfectly fine
Old 11-07-2002, 09:32 PM
luti luti is offline
Send a message via AIM to luti
The Jackson Racing SC runs 6psi stock, but with the pulley kit available from JR you can up it to 8psi. Your EX should take 6psi no sweat. I am planning on getting a JRSC when money is available, then a clutch (but not until mine wears out).
T3/T04E turbocharged ricer.
Old 11-09-2002, 10:13 AM
CivicEXdude CivicEXdude is offline
hondatool, how do you like your turbo? have you dyno'd. I have a 2000 EX and am wanting to go the turbo route...Which one did you get? Any problems? Thanks.
Old 11-10-2002, 01:52 PM
i have the greddy kit on from the 5 gen civic...so far its working great...i havent had a problem with it...im running a little rich but im getting that fixed soon...its kinda killing my gas mileage but with forced induction you really cant worry about gas mileage ya know!...i havent dynoed yet....i cant remember the website but check out www.turbod16.net i think it is...if not do a search on it...its for sohc turbos...it helped me a bit
JETTA Clutch Trouble... HELP! m007steve '97 - '03 0 08-02-2010 03:43 PM
P0341 Cam Pos Sensor Help!!! catesja Montana/Montana SV6 0 07-30-2007 03:46 PM
Cam Gears or help Scofo Performance 3 02-05-2007 12:15 PM
Cam Position Sensor help jesus_man Legacy / Liberty / Baja 2 03-09-2006 12:19 PM
skunk 2 cam gears, need help vetec98sh Prelude 0 09-08-2005 01:45 PM
