Old 05-23-2007, 08:31 PM
kjkelsey kjkelsey is offline
2002 2.2 L Grand Am
I have been having a problem for the last couple of weeks. When I go out in the morning it will start fine. After I drive to work, 15 miles, and it sits for a few hours it will not start. It will crank but will not fire. I have changed the plugs, fuel filter in the last month. It would start if I used starter fluid to get it going. Now it will not start at all. The only fire I get is when I'm spraying starter fluid in but I'm not getting any fuel. ANY SUGGESTIONS PLEASE!!!!
Old 05-23-2007, 08:46 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2002 2.2 L Grand Am
Welcome to AF.
Your post has been moved from Grand Prix to the Grand Am forum.
Timeslip 08/12/06
AF Community Guidelines
Old 05-24-2007, 10:42 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF kjkelsey.
Does the fuel pump run when you are having the starting troubles?
Then I would have fuel pressure checked.
Could be the fuel pump,, pressure regulator.
Though are you sure you are getting good spark ?
The Ignition modual/coils could cause a weak/no spark issue.
1999 Grand Am SS 3.4 OHV
