Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 05-23-2007, 01:09 AM
rob67gmc's Avatar
rob67gmc rob67gmc is offline
Electric water pump???
Anyone use an electric water pump? Pros, cons, brands?
1989 Camaro RS convertible
Engine & trans has been changed to 350 TPI w/ 6-speed manual
K&N filter
BBK 58mm Throttle Body
Richmond 3.73 gears
Spohn full length adj. torque arm
Spohn lower control arms w/ poly bushings
Spohn Adj. panhard bar w/ poly bushings
Spohn front & rear sway bars
Spohn weld-in subframe connectors
PST complete front end rebuild kit
KYB struts & shocks
Old 05-23-2007, 05:00 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: Electric water pump???
I have a Meziere and they are pretty much the best you can get. I had originally bought a csm or something like that and was not impressed at the fin design so I sent it back. The instalation itself is fairly simple. You take off the water pump, press out the propeller assembly and then bolt in the electric pump to the old pump, the only part that takes any time is trimming the fan shroud but that is fairly simple. If you buy one I'd recomend a painless wiring kit. It has everything you need and should only take about 15 minutes to wire.
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 05-23-2007, 11:29 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
What's the advantage of an electric water pump? Less drag on the motor?
Old 05-24-2007, 11:22 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
more hp, not the best for street cars, there aimed towards race cars
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 05-25-2007, 12:26 AM
PeteA216's Avatar
I kinda figured. I can't see an electric water pump holding up too well in stop and go traffic on a 95 degree sunny afternoon.
Old 05-25-2007, 08:01 PM
actually a meziere pump comes with a 2 year warranty and is guaranteed for a minimum of a 2500+ hr life expectancy... so thats a better guarantee than a stock pump... + they flow more GPM and reduce drag on the timing chain/crank gear/cam gear...
Old 05-29-2007, 12:41 AM
rob67gmc's Avatar
From what I've read about several different pumps, the Meziere sounds like the best. I may try one when I get a few other things out of the way.
K&N filter
Richmond 3.73 gears
KYB struts & shocks
