| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Thinking of buying Iwata Compressor
Just wondering... is this compressor any good:
Iwata Studio Series Smart Jet Pro compressor or any particular recommendations? I notice that it doesn't have a chamber or something which air can flow into to provide a smooth airflow? Any ideas? |
Re: Thinking of buying Iwata Compressor
Very good compressor, I highly recommend it.
An A+ compressor!
How does it compare to say against this:
http://www.wonderlandmodels.com/Reve...ctx365444.html and http://www.wonderlandmodels.com/Ripm...uctx23954.html Which one would last me basically once and forever ? lol. coz I want to buy one which I won't need to upgrade for ages! Also, I was reading in some website you can connect 2 airbrushes to a single compressor? How does that work? Do I need to buy some sort of splitter? |
The Iwata Studio Series Smart Jet Pro compressor doesn't seem to come with a tank and can only do 35 psi (a little low for automotive paints). Out of the other 2 I personally choose the Ripmax RCP104 Compressor with Air Tank. Reason: Larger tank, means it doesn't need to turn on as much. As for the adapters I would suggest you look for the type you need in a hardware store that sells compressors or Mr. One Touch Hose 1/8(S) Straight and One-Touch Plug for Mr. One-Touch Hose 1/8 S . HTH, Steve
Please read the following linked articals before posting a question. Once you have and still have questions, try to post your questions clearly. This will make a lot of people's blood pressure drop back to normal, including mine. NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST AF Car Modeling Tutorial, How-To and Product Review Depository AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0 And finally,I wish you all happy modeling
The Iwata uses an attached hose to buffer the pulses. it only comes on when you press the trigger on the brush and is wisper quite when running.
The only thing that has kept me from buying one is the fixed pressure. You can turn down the pressure by opening the drain on the trap a little but then the compressor runs all the time.
SCCA 7, The lost Z Contest entry thread: Mystery? Beetle + Boxster = Bugster, P.T. Panel:click here Diablo Roadster: click here, & Porsche C2 Cab |
Hey Steve,
Thanks for the reply... I had a look at the Revell compressor and it says it develops 5.5 bar which is about 80 PSI. Also, it says in the extras: air tank with condensation drain valve... What does that mean? Is it an extra tank? Thx T Quote:
Most tanks will come with some sort of drain valve. The pressure should be enough for modeling needs, but if you are determined to get this set I would suggest you also look into a larger storage tank if you don't have the liberty of letting it run all the time. One strange thing I just noticed... It doesn't state the HP the compressor has, but guessing from the size I'd say 1/8 HP...1/4 max. As for the price... let me put it this way... I could get 2.5 compressors for more or less the same money. I paid around 60.5 GBP for mine and it has the same functions capabilities as the revel. Here's the website for the company that made my compressor: http://www.sparmax.com.tw/ BTW: max pressure :5.5 bar (80psi... that's the max pressure it can produce, but working pressure will be maxed at around 55-60psi.) HTH, Steve
Thanks yet again for your reply... I was browsing our local shops website and I had a look and saw this compressor at half the price
http://www.machinemart.co.uk/shop/pr...-compressors-2 My main concern was the weight but I need to pop down to the shop to see if they have any for me to check. Anyway, It says that it has a 6l air reciver ? Is that just the tank? It has 1.25hp - is that going to be noisy ? Finally, it seesm to say main uses is for airgun - so do u know if it will fit the airbrush ? It also has a output pressure regulator valve which I assume means that the pressure can be changed? And also has safety valve. Max PSI is 115 - do u think this might be a bit too powerful ? I might well buy this if it isn't more than 15kg - a bit of a beast to carry me thinks! |
I use a similar kind of thing except 4-times larger (24l tank) and am veryhappy with it.
Yes, it is quite noisy when filling but the 24l tank takes 90 seconds to fill from empty and 24l o4 air compressed to 8 ATMs is good for several days modelling so I have not found that a problem (I just fill during the day and not at 03.00 a.m. )You will need to add a water trap and air filter to the set-up or yo will regret it
Guideline for happy modeling: Practice on scrap. Always try something new. Less is more. "I have a plan so cunning, you could put a tail on it and call it a weasel" - Edmund Blackadder |
6L air receiver = 6l air tank 1.25 HP = Slightly noisy, but as Klutz pointed out if you get a larger tank it won't bother you. The higher the HP the faster your tank fills up. Main use airgun = most compressors come with 1/4" attachments... you will have to buy and adaptor with a 1/8" head. The regulator valve on the 'bandit' is one of the more basic types, thus giving you poorer control. If you plan to add a water trap and a good air regulator, then this won't be a problem. Max PSI 115: There is no such thing as too powerful. Sure, you might not ever crank it up to 115, but its there if you need it. The higher the HP of the compressor, the higher the PSI will be. It can always be regulated. I have a max of around 60 psi on my compressor. Do I use it to paint? No. But I use it a lot to dry off or clean my models, and I wish I had more PSI. I am planning to get a 2HP compressor once I move. If I can afford it (the noise) I might even get a 4HP and place it in the garage or somewhere, then connect an air line to where I model and have a large storage tank there. With the HP amount on compressors, all I can say is the more the merrier. If you are into other things, such as photography, woodwork etc etc... a compressor will make your life a lot easier. (I use my compressor the shoot air when cleaning my camera lenses, clearing sawdust from my woodwork, etc etc.) What kind of budget are you on for this setup? Do you have a dedicated area for modeling? If you have a compressor running on and off, will you get in trouble? Glad to help, Steve
Right...
I've decided to go for this Clarke Bandit as you guys recommended it... Just wondering, regarding the adapter, which one should I get: http://airbrushes.com/index.php?cPat...1bc7f0d36a6077 I notice it says that you can get some Y piece so you can connect 2 airbrushs to 1 compressor? Which one should I get to have that specific setup? I noticed that when I browsed the website, one of the related items to the compressor is a 1/4" male adapter or something... I also have this http://www.1999.co.jp/eng/10006429 I'm not sure if it is some sort of moisture trap but I got recommended this by someone in a model shop when I bought an airbrush in hong kong... There are a few choices here but I see they are quite expensive but I don't mind investing in it if you guys think it should be done? http://airbrushes.com/index.php?cPat...1bc7f0d36a6077 Anyway, thanks a lot for your help so far!
Can anyone help?
My advise:
If you need to connect 2 or more AB's to the compressor (1/8 BSP Ab's only) then I would strongly suggest you buy Gunze's Ps-280 Ps-281 seen here. These 2 'sets' will allow you to connect 3 x 1/8" AB's on your compressor. (This is what I use, cost me around 40 bucks(can't really remember the exact figure) for the lot) If you want a futher detailed answer, let me know what you are planning to attach to your compressor, and what you might consider getting in the future. That way I can make a more detailed suggestion. (BTW, a lot of the stuff in Airbrush.com is out of stock.) I would suggest you buy attachments in person not over the internet, compressor too, frankly. Reasons: cheaper, you know what you are getting (what the stuff is made of matters too), you know where to go if the attachments leak (I work for a plumbing supplies store and KNOW that even the best brands have stuff that is messed up). HTH, Steve
How many of each should I get? because I notice that they don't seem to 'split' or divide one connection into to?
I found some in stock here: http://www.luckymodel.com/scale.aspx...S&toolstype=AB |
