Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-23-2002, 03:38 PM
mengy mengy is offline
putting vtec head onto a D15 block
is that possible?
I think there is a D series motor that is vtec
??? would it be worth the time and effort and $$$?
Old 10-23-2002, 04:15 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
http://www.automotiveforums.com/vbul...threadid=69562
pretty much the same putting it on a 1.5 or a 1.6...you'll just have to convert to mpfi with the 1.5... (unless you've got a hf)
SOLD!
Old 10-23-2002, 05:38 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Swap
It's called a mini-me swap and to me no it isn't worth the cost of gaskets and time. Atleast buy the whole dam thing and not just the head.
Old 10-23-2002, 05:42 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Swap
Head = $100
Gaskets = $50
time= free
Whole motor $400 - $600
hmmmmm
results, priceless. j/k
Old 10-23-2002, 05:55 PM
Swap
Your going to need more than $150 to do it RIGHT. Yeah you can half ass it like anything else or you can do it the semi-right way.
The Mini-Me conversion. For those who don't know its a D16z6 (or D16y8) SOHC VTEC head swapped onto a D15b7 block.
What is needed? Here is the list I have so far from another site:
D15B7 block
D16Z6 head
D16Z6/D16Y8 head gasket (the D16Y8 headgasket is almost 1/2 the size of the Z6, so it will up the compression some)
Civic VX timing belt
Civic HX spark plugs (not required but recomended)
D16Z6 ecu
D16Z6 intake manifold (including fuel rail and injectors)
D16Z6 distributor
How much will it bump up compression? I've heard that using ZC pistons will further up compression, how much more are we talking?
What are the disadvantages of this swap?
I know I could probably swap in a D16 for nearly the SAME price when it's all said and done.
And here is a quote from Aggressorsol (Tim) from the del sol board on Hondavision. He knows more about D-series than anyone that i have ever talked to.
D15B's r/s ratio is better than the D16's. How do you think they dropped the displacement? The pistons are interchangeable... So that means it's a short stroke D16, with a Z6 head.
delScho's D15B in the VXi hauls fairly well, but in my honest opinion, I wouldn't do the Mini-Me swap. (and this is from the D block lover from hell) I liked the pull of the non-VTEC D15 better. The D15 on boost is about the baddest ass little whomper out there. Tachs up quick, and shifts low. Drop an Si ratio tranny in it, and it's mean package at 10 psi.
Now, what I WOULD do, is go with a D16Z6 block and head, drop in VX pistons and rods, and go to town.
ORRRR. Try this one. (the "street motor project") Take a D15B7 block. A D13 short stroke crank. A D16Z6 head w/ Zex cam. Custom ALUMINUM rods, and your choice of high compression pistons. It's a LIGHT crank, use light rods, light pistons, and a VTEC head with a high rpm profile that's oversized for the displacement. Spin the bitch to 13,000 and watch the crank fly out the bottom the first time you drop the clutch. But it'll sit on the starting line spinning 13K holding on for dear life!!
If I were you honestly, I'd just find a D16Z6 lower end to go with the head. You'll be happier. It's not worth the cost of gaskets.
Stick
Old 10-23-2002, 11:41 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
What??!?!?!?!?!?
Why isnt a mini-me worth the time, 130-140 hp for the price of gaskets the head and a vtec activator.
Not to mention that the a6 block is considered the best d series block.
My plan starting sometime next week is d16y8 head, a6 block, y8 oil pump, z6 gasket, a6 distro, injectors, and ecu, with a zdyne 1 wire.
Old 10-24-2002, 01:23 AM
91civicDXdude's Avatar
130-140hp? i belive you're a little off on those numbers. try about 110-120hp if even that much. The stock d16z6 has about 125hp so i doubt using a smaller displacement is going to ADD 15 hp
Old 10-24-2002, 09:11 AM
Thank you
I was going to have to correct him. You'll be lucky to see 115 whp. I would plan on 110 whp at best. So again NOT WORTH THE TIME, get the whole damn motor.
Old 10-24-2002, 10:45 AM
d16a6=102
d16y8=127
mini-me with a6 block and y8 head will at least be above 127 because of the raise in compression, why get a whole vtec engine when you get a better block and higher compression from the a6 block I already have?
Old 10-24-2002, 10:53 AM
marked001's Avatar
Moderadur
that may be true if you go all the way through with it and swap up to OBD1...otherwise, the engines gonna be starved for fuel, spark, etc. with the stock ecu when the cam changes and you're not gonna see that 127...plus, that 127 is at the crank..
I started this swap and I definitely spent way more than I was planning on...so I scrapped it and got a zc.. (not to mention I broke something major...but still )
SOLD!
Old 10-24-2002, 12:59 PM
I will be using the zdyne 1 wire to compensate for the missing fuel maps and so on. I am not trying to say this is the best swap out there, but dollar for dollar you get roughly 20 hp for a low price, while replacing older parts with newer better designed ones.
Old 10-24-2002, 02:04 PM
if you look at the original thread, he said swapping a VTEC head onto a d15 block, not a d16a6. doing the mini me swap onto a d15 block will give you less horsepower. granted, you will have higher compression, but it is a smaller displacement.
Old 10-24-2002, 04:20 PM
I realize that it would lower the hp with a d15, but the premise is still the same, and the question becomes for each person is it worth your time and money to do a mini-me vs any other of the swaps available. My opinion is yes, depending on how cheap you can aquire a vtec head.
Old 10-24-2002, 05:18 PM
So how much would it actually cost? wouldn't I have to get an mpfi also and dizzy... ecu ?
Old 10-24-2002, 05:50 PM
if u have a dx u have to convert to mpfi, si and i believe hf dont.
putting VTEC head on non Vtec block for 94-97 accord indmny453 Engineering/ Technical 0 12-07-2004 10:55 PM
putting VTEC head on non Vtec block for 94-97 accord indmny453 Accord/TSX/Accord Hybrid 0 12-07-2004 10:54 PM
D16 head on D15 block TheSilentChamber '88 - '91 Civic | CRX | Wagon | Shuttlee 15 08-07-2004 03:50 AM
vtec head onto d15b2 can i do it? fredthedragon '88 - '91 Civic | CRX | Wagon | Shuttlee 4 06-03-2003 10:11 PM
Closed Thread
