Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-21-2007, 08:46 AM
JoeTex JoeTex is offline
What Is Sea Foam??
I'V READ SOMTHING ABOUT A SEA FOAM TO CLEAN THE ENGINE IS THAT A MYTH OR A FACT?
Old 05-21-2007, 08:50 AM
Doge dude Doge dude is offline
Re: What Is Sea Foam??
it does clean out the bad engine carbon I put it in my dodge 1500 4.7 liter and it run great now. but when you buy it put two bottles on each tank of gas for about a month and it will be cleaned out for a long while.
Old 05-23-2007, 07:34 AM
Ok And Where Do I Find This Product??
Old 05-23-2007, 11:22 AM
carlos80 carlos80 is offline
Checker, Autozone, NAPA.
Old 05-24-2007, 09:34 AM
Ey'thnx Guys But One Other Curiosity..what Can I Use To Clean The Exssesive..oil That Clumps In The Engine After Yrs Of Use??cani Use One Of There Seafoam Products????thnx Yu'all
Old 05-27-2007, 03:16 PM
97cv's Avatar
97cv 97cv is offline
ok here is the best most concentrated way to use this.AT YOUR OWN RISK IF YOU KILL YOUR CAT CUZ YOU USE DINO OIL THAT IS NOT MY FAULT.
You need 8 new plugs,and oil change supplies along with one can of seafoam. I did mine at night with high wind.Search youtube > seafoam
Locate your PCV valve
Take off the hose and turn up
With engine running SLOWLY pour the can down this hose
You will have to play with NOT stalling your engine til 1/3rd bottle is left
THEN DUMP WHATS LEFT...stalling the engine.
Replace hose to PCV
Go away for 1/2 hour....waste time as you see fit.
Come back and start car...It might not run the first time...thats ok try again
REV car to a comfortable high idle.ITS NOT AN RPM RACE just more then idle Continue this till its all clear
Wave off nieghbors who think your garage is on fire
I ran mine up and down the street after exhaust WAS CLEAR just to WOT
Change oil...too bad its hot you want it that way before the carbon settles
Change plugs that might have carbon fouled
Old 05-27-2007, 03:33 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
I've also seen it at Tractor Supply Center for a good price. You can click here to see if there are any stores in your area:http://www.mytscstore.com/ .
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 05-29-2007, 07:09 AM
Hmmm I Bit Too Complicated For Me..and Besides I Recently Changed The Plugs..and Expensive One's For That Matter So I Guess Itll Have To Wait Till Next Time ..
Old 05-29-2007, 10:54 AM
97cv's Avatar
Hey JOE TEX ..Do you live in texas ?
Old 05-29-2007, 06:53 PM
463's Avatar
463 463 is offline
see the link http://www.seafoamsales.com/products.htm add an average 1 ounce per gallon of gas in the tank. One pint treats 10 quarts of oil (avg. 1 1/2 ounce per quart). With warm engine running, SLOWLY poor 1/2 pint through carburator, throttle body or direct manifold vacuum line that will feed ALL CYLINDERS. Possible sources are P.C.V. valve or brake booster line. Turn ignition off. Restart engine after 5 minutes. Be sure exhaust is well ventilated. Fumes will be extreme for a short period of time.
Old 05-29-2007, 06:54 PM
463's Avatar
463 463 is offline
it works good. just read the directions. i haved used 3 cans over the last 2 years in 2 & 4 stroke in the oil, in the gas & though the vac and inj/carb with real good results. you will be impressed . the seafoam trans tune i bought still sits on my bench as it requires a trans flush after you use it and i just did a pan drop and filter in the chevy van and decided not to use it. i use it in the snowblower, lawn mowers, power boat, cars , van new and older carb & inj. i also have a number of close friends that use seafoam with the same results. it gets in and cleans out the carbon . for a test try a little in the gas of a lawn mower for a tank of gas. look at the spark plug before and after for your own eyes. then on the next tank of gas just see how easy it starts. hope you have as good a luck as i have with seafoam.
Old 05-29-2007, 06:57 PM
463's Avatar
463 463 is offline
it does not kill cats when used in the fuel thak as directed with a non oil burner
Old 05-31-2007, 12:56 AM
97cv- Hey JOE TEX ..Do you live in texas ?..
'''''''''YEAP I JUST DONT LIVE IN TEXAS..I'AM ALSO FROM TEXAS..HOOWDY PARTNER'S''''
Old 05-31-2007, 11:03 PM
97cv's Avatar
Well I was gonna offer to Help ypou do it .....I live in Michigan
Old 05-31-2007, 11:22 PM
There is another discussion ongoing in another forum on this site concerning Seafoam. Here is the link if anybody cares to read more on the subject:http://www.automotiveforums.com/vbul...d.php?t=709643
