Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 05-18-2007, 08:50 PM
e1krimez87 e1krimez87 is offline
My clutch won't come back up!!!
I have a 97' civic for about 2 months now.. it has not given me problems until now... you know like when I turn the car on, after I release the clutch, It just stays stuck like it was glued to the wall. i have to pull it back to its normal postion with my foot.. Now Im not the guru of cars and how they work... but I do know that it shouldn't be acting this way.. something is wrong obiously.. so thats why I just registered to this forum a minute ago.. I read many of you know your thang about cars. just give me some feedback like what should I check or change.. hopefully is nothing complex. thanx in advance ...E
Old 05-20-2007, 08:40 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: My clutch won't come back up!
Sounds like a bad master cylinder. Could be a bad slave cylinder too.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 05-20-2007, 09:54 PM
240slider's Avatar
240slider 240slider is offline
Re: My clutch won't come back up!!!
check your clutch fluid level and inspect for leaks .If good you may have air in the system.
Old 05-20-2007, 11:17 PM
Civic_dreamer Civic_dreamer is offline
If you don't find any leaks and you bleed the system and it still don't work you could have either the mast or slave cylinder going out...
Old 05-21-2007, 01:26 PM
jclark jclark is offline
And check the spring on the clutch pedal under the dash.
Jim C.
Old 05-21-2007, 01:43 PM
Scrapper Scrapper is offline
AF Premium User
sounds like a spring off or it's got air in the slave cylender it's on the side of the tranny see if it looks wet if it is your going to have to replace it and bleed the air out of it...but if not leaking i'd say spring......good luck...
scrapper....
Old 05-21-2007, 03:34 PM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
sounds like youre still driving it... captain adventure
definitely a bad master cylinder tho
ECNATSISER AL AVIV
Old 07-04-2007, 12:59 AM
Hunter1 Hunter1 is offline
not always a bad master cylinder... air in the line/low fluid will cause the same problem. top off the fluid and bleed the line. wash rinse repeat
Old 07-04-2007, 12:18 PM
I had my mechanic do the leaking of the air for me for free... it had some kind of oil in the system where dot 3 goes, I don't know who put that liquid there, I guess the old man who I bought the car from.. anyways it worked good after the cleanup but then 3 weeks later, the clutch disk was burned out so he replaced the whole system with everything new.. my car works smooth now... thanks ya'll
