Old 05-17-2007, 01:39 PM
MidMazar's Avatar
MidMazar MidMazar is offline
300c
AMT kit used, tamiya black used for the body. Seems to have a little orange peel, i'm satisfied with it so i won't bother further polishing it. Interior was done semi and flat black acrylics. Fujimi wheels used. Comments and questions always welcomed.
Some new photos of my older work,
In Progress
Old 05-17-2007, 01:59 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Re: 300c
Nice!
The front grill seems to lack depth in you pix.
SCCA 7, The lost Z
Old 05-17-2007, 02:08 PM
Viccario's Avatar
Viccario Viccario is offline
Re: 300c
Looks really good I can't see the orange peel, the grille possibly looks like that because cameras struggle with the different exposures when trying to compensate for a black bodyshell with a bright background. The Nissan from your older builds looks nice too if lacking a bit of shine.
Old 05-17-2007, 04:58 PM
white_R34's Avatar
white_R34 white_R34 is offline
Re: 300c
just use the wash on thing like that grill. I like that VeilSide 300ZX. SAS wing? yah likes that and the Binz-O wheels tite if you are not going to a show the paint is not all that bad but if you want to do better just mix a thiner paint check you air floe or psi and sand it use some wax. If the car isn't painted witha enamel if you did just mix a 30%-Paint/10%-thinner/60%-High Gloss Clear as the last cover. No need to wax,if you have a 100 watt light bulb the heat from the bulb can help smooth the paint, what you have to do is after you have painted the model keep the model on it's mount and pass the model near the bulb some what close so the heat will smooth the paint that look like its not as smooth as you want it. I know this sound weard but for a long time at the show I go to here people allways ask how do you get (Enamel) to lay so smooth man I will always say I don't know "srugging my shoulders". I used this to win alot hope this will help you or any one if you or any one needs a mor indepth info on this let me know.
Old 05-27-2007, 01:46 AM
Jaymes's Avatar
Jaymes Jaymes is offline
Re: 300c
that's a clean build...and that z32 looks good
Old 05-27-2007, 10:10 PM
Alfa 147's Avatar
Alfa 147 Alfa 147 is offline
Re: 300c
Nice and clean build, i really like the color . The wheels look a bit small though.
Alfa147Models.tk (in spanish)
