Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-16-2007, 12:43 PM
Cbpcop's Avatar
Cbpcop Cbpcop is offline
4 Runner fuel filter(s)
Good afternoon,
I've got a '98 4 runner with the 2.7 ltr 4 banger. Recent rough/stumbling idle has improved greatly with several shock treatments of concentrated fuel injector cleaner through the tank but there is still a slight hint of the original problem. Currently has 68500 on the OD. Books are packed away and I think it's time to change the fuel filter(s). Can someone reliably tell me where it/they are located? The help is greatly appreciated! Thanks.
Old 05-16-2007, 07:36 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 4 Runner fuel filter(s)
Fuel filters don't normally need replacing. However, since you asked, it is under the intake plenum bolted to the side of the engine, middle - front to back. Your problem is more likely one or more injectors clogging than your filter.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-17-2007, 05:59 AM
Cbpcop's Avatar
Brian,
Thanks for the input. The engine continues to improve in smoothness and even running so I'm going to let things continue as they are going rather than start taking things apart (fuel filter). Additionally the tranny seems reluctant to downshift to passing gear when needed. Any ideas there? Thanks in advance!
Old 05-18-2007, 10:14 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Originally Posted by Brian R.
Fuel filters don't normally need replacing...
They do if you wheel your truck.
I run 3 in series.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 05-27-2008, 01:01 AM
jokerwanted jokerwanted is offline
my mom has a 97 4runner, how do you get the fuel filter off?
Mr.Oz
Old 05-29-2008, 12:32 PM
Cbpcop's Avatar
Hey Joker,
I never went in after the thing. I opted for the cheaper and less complicated course of action and added STP fuel injector cleaner concentrate - enough for the 18 gallons of fuel the tank holds. It's worked fine so far - about every 3rd or 4th tank. Try it out before the mechanical option. Good Luck
Old 06-22-2008, 06:45 AM
beswift beswift is offline
Last winter I replaced the front fuel line and filter on my '95 4-Runner. It was a terribly difficult job as the fuel filter is located in a very tight spot. I still haven't gotten my left thumbnail back. At 155K miles, I didn't think it was a bad idea, but would not do it again.
Old 07-24-2008, 06:50 PM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
I have to agree with Brian the in-line filter is probably not your problem and on the 4Runners it is a pain in the A$$ to replace.
Hey fourwd1 Howdy!! Even if you're wheelin what in earth are you doing to get dirt in the liquid gold tank?? Man I wanna ride with you!!!!
