Old 10-21-2002, 08:15 PM
mengy mengy is offline
Stock everything! And won't pass smog!
Guys says timing "might" be off... it'll cost me 150 for him to fix it... I'm not spending 150 on a maybe!
Old 10-21-2002, 09:33 PM
91zc 91zc is offline
Do a tune-up, change the oil, make sure your cat is not clogged up, and buy yourself a timing gun and check the timing yourself. Easy to do and it definitely won't cost you 150 bucks.
91 civic 4dr
b16a
14.8@94
Old 10-21-2002, 09:59 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
your saying your car wont pass emissions with messed up timing?
2002 Acura TL Type S
1991 Honda Crx Si
Old 10-21-2002, 10:04 PM
GTA's Avatar
GTA GTA is offline
Whee..
Nope it wont. My failed cause of timing being off.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 10-21-2002, 11:21 PM
TrailerParkJake TrailerParkJake is offline
Send a message via Yahoo to TrailerParkJake
what part of emissions did it not pass??
theres a lot of simple shit you can do depending on what its not passing
oh yeah, run the piss out of your car right before taking it into the shop for the next inspection
When I started reading about the evils of alcohol, I quit reading .
Old 10-22-2002, 10:51 AM
Thanks guys... my dad and I checked the timing last night... he says he couldn't find the numbers or something? How are you suppose to tell how much it's tilted? We got a timing gun but all we saw was the little white mark and no numbers... or are we going at this all wrong? my dad is used to fixing toyotas so he's always complaining about how honda's parts are so poorly engineered.... blah blah blah... help?
Oh one more thing how do I check to see if my cat is clogged?
Old 10-22-2002, 10:52 AM
I forgot what part but the guy said that the highest it could be was like 120 and mine was at 2xx something... maybe that'll help
Old 10-22-2002, 01:03 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Smog
Change the oil and clean out the Throttle body before you go and make sure that the car is warm when they test it. Run it good and hard before you get there and try not to let it sit too long and cool off.
Old 10-22-2002, 02:59 PM
heres a how-to on c-speed racing.com....
http://www.c-speedracing.com/howto/timing/timing.html
thats for a b18c, but its basically the same thing as on your civic motor
Is it failing when its at idle or when its under load, or both?
Old 10-22-2002, 04:28 PM
It's failing @ both
Old 10-22-2002, 07:16 PM
Smog
Might want to consider that facts that the cat is goin bad or you could have a bad 02 sensor.
Old 10-23-2002, 02:42 PM
Re: Smog
If I had a bad o2 sensor wouldn't my ecu tell me?
I think I can replace the cat...
Old 10-23-2002, 02:55 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Re: Smog
Not always.
Old 10-23-2002, 04:24 PM
How much $ and trouble would it be to replace my cat and my o2 sensor?
I wouldn't have to get new headers would I?
Old 10-23-2002, 05:15 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
Both r easy:
sensor is just a wrench or special socket.
cat is bolt in so it's just a few bolts.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
1998 sebring won't pass smog rubgom Sebring | Sebring Coupe | Convertible 0 03-12-2005 01:57 AM
1998 Cavalier won't pass smog!!! snoopyq1972 Cavalier Problem Diagnosis 0 01-30-2005 08:51 PM
HELP! Car won't pass smog! babyneo CL | Inspire | Saber | TL 1 10-22-2004 02:47 AM
My 91 Accord won't pass smog! Help 1991AccordSe Accord/TSX/Accord Hybrid 3 03-01-2004 03:25 AM
93 Bravada Won't pass smog 4080greggory Bravada 3 02-07-2004 12:27 AM
