Old 10-18-2002, 05:00 PM
krnlpanik krnlpanik is offline
Send a message via AIM to krnlpanik
CRX starter motor
well....I'm having trouble starting my 91 crx. I went back to school and came back home about a month later, I had forgotten to disconnect the battery and all that happy stuff. So the terminals were corroded to the point where it wouldnt even turn over. So i cleaned them off and it started up almost normally, it choked out and died. when i tried to start it again, instead of the normal *pulsing* starter motor noise(like the engine is turning) that Im used to hearing, instead I hear a *constant* starter motor noise(like the motor is just running free). I had a friend turn the key for me and the belts and all are turning. So i dont believe the motor itself is bad.
A local honda mechanic said that it could be caused by the plugs getting "wet" and reccomended that I take out the spark plugs and dry them, and if nessecary sand them. Well, that didnt work.
Someone else suggested that I wasnt getting any compression, but I dont know what I would do about that or if that would even be feasible--could the gaskets dry out that much in 1 month?
Has anyone else expirienced this problem? How can I fix it?
Thanks,
kris.
Old 10-18-2002, 05:16 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: CRX starter motor
Thanks,
kris.
First off, if you were getting zero compression, your motor would be toast. The only way to check compression is with a little compression tester gauge. But that's not your problem.
What it sounds like is either plugs, wires, or distributor. If the distributor got so wet inside, it caused corrosion, etc. That could prevent a startup. A easy way to check if the distributor is firing, is to hook up a timing light, and crank the motor. If the light flashes, you know the distributor is capable of firing. Do that on each wire. You can also test the wires themselves, using a ohm reader. The correct ohmage (new word) can be found in a haynes manual.
As for the plugs, I dont see all four plugs going bad at once.
Thats probably where I would start.
Old 10-19-2002, 08:01 PM
95civicman 95civicman is offline
i can't even get my car to turn over. no pulsating or anything. i checked the starter and the wire is hooked up good and it's not the ignition because i can hear the injectors hissing in fuel. so you think that i need and new starter and how much do they cost? thanks
zc powered 89 CRX SI with some more stuff.
Starter motor to starter solenoid wire Plymouth Voyager 1993 Voyag1993 Caravan | Voyager 3 02-13-2007 12:52 AM
third crx starter c8r9x '88 - '91 Civic | CRX | Wagon | Shuttlee 10 02-17-2006 12:08 AM
CRX Starter Gone shaddr3 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 03-13-2004 08:26 AM
May need new starter motor. Where to get? PatrickG20 General 3 03-06-2002 02:10 AM
Starter Motor died today nismo_gt Engine 7 02-28-2002 05:49 AM
