Old 02-12-2006, 04:37 AM
c8r9x c8r9x is offline
Send a message via AIM to c8r9x
third crx starter
my car keeps going through starter ill get a new one it will work for a while then i go to start my car and it takes a sec to turn over and sometimes it will just click i have to push start it anyone know whats up with my car??? thanks
Old 02-12-2006, 12:19 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: third crx starter
bad ground?
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 02-12-2006, 04:42 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
yeah sounds like you have a wiring issue.
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 02-12-2006, 09:39 PM
thanks im going to go ground crazy and ground everything and see if it works
Old 02-14-2006, 03:18 AM
well i made sure everthing was grounded and put a couple more grounds in and guess what i stiil had to push start it i was almost late for work im glad i have a small car the ground didnt help at all you think i should go to honda and get a new starter insted of autozone ive burnt 2 and this one just about to take a shit on me
Old 02-15-2006, 09:26 AM
Jos4DCivic's Avatar
Hows your flywheel/flexplate teeth look? does it grind at all?
91 Hatch SI
Finally painted!!!
Old 02-15-2006, 09:34 PM
no it doesnt grind at all i recently changed my clutch and flywheel and the flywheel was fine this thing has stumped me sometimes it works fine but if it sits for a long time it wont start everytime i turn the key it will click once sometimes if i want for a a little bit and try it again itll start the only thing i can think to try now is go to honda and get a starter
Old 02-16-2006, 08:34 PM
skotman's Avatar
skotman skotman is offline
what about your battery have you checked it to see if it is to blame i mean it could be doing dead so maybe its the alternator too have you checked the alternator well i remember having a similar problem with my car but i cant remember what i did to fix it oh well good luck tell me if you fix your car i hope its something cheap bye
Old 02-16-2006, 08:39 PM
skotman's Avatar
whoops! forgot these:
Old 02-16-2006, 10:40 PM
no it not the alternator its only about 6 months old and the battery only about 4 every time i get a new starter itll work just fine for a while then just start to crap out well tomorrows payday so im gonna go to honda and get my 4th starter hopfully it will be the last one i hate changing it my hands get all banged up thanks for the suggestion though ill let you know what happends
Old 02-17-2006, 12:08 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
actual battery voltage reads? wiring from the battery to starter is clean and tight............if so, jumping the connections from the battery and ground to the starter resulted in...............and if they are tight you confirmed with readings on the starter? thermostat housing ground is tight and clean?
if youve gone through 3 starters already and plan on getting a fourth, its kinda like beating a dead horse to death again for the fourth time.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
