Old 10-17-2002, 10:27 AM
b16a1civichb's Avatar
b16a1civichb b16a1civichb is offline
JDM 4-1 Header Install
Ok I am gonna order a JDM 4-1 Header but i was just wondering if anyone has installed one of these into there EF Civic with B16a. Just curious how difficult it will be and if it sits low to the ground.I'm also intrested as to how to get 2 oxygen sensors on it.
Thanks
1990 Civic HB
Old 10-17-2002, 10:56 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Re: JDM 4-1 Header Install
Thanks
Well you also need to buy a cat for it. Its not gonna be that low to the ground. Not sure about the o2 sensors though.
Old 10-17-2002, 08:56 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
You may have to hammer your crossmembers to fit the jdm header or purchase a Z10 or placeracing or any aftermarket ones being sold. If you have a Hasport billet mount kit, it's supposedly 1/2 an inch taller than the older or other models so clearance is ok. My bottom shield was late in delivery so this is what happened when I accidentally drove through a street being prepped to be paved and all the man-holes were exposed. You can also see the clearance from the picture.
Here's how the old crossmember looked like...
About the 2nd O2, I'm running only 1 O2 sensor (LS motor) but will eventually get my PR3 ECU chipped to eliminate 2nd O2 when I drop the Vtec motor. You can get an attachment to the header from inlinefour.com or jdmhonaparts.com to accomodate an O2 then run the
2nd one from the CAT.:flash:
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 10-18-2002, 11:56 AM
Thanks
Thanks for all the great pics. I'm still debating whether to get the JDm one or the regular one cause of all the added stuff i have to do because of the size of the collector and O2 sensor and the cross member. I was thinking about just getting the 90-91 LS one that is 2 piece. But i dunno
BTW do you have a pic of the new crossmember?
1990 Civic HB
Old 10-18-2002, 12:01 PM
EF_LSVtec's Avatar
Let me tell you, I replaced this header once with a stock 2pc cast type R exhaust manifold and the difference is noticeable...I did it to pass smog but found out later that it would have passed with the jdm header. I have the cast type R too in case you want it...$75 plus shipping. its a heavy sucker though...:flash:
AF Bay Area Crew
Retired SOLD 1/08
Old 10-18-2002, 12:05 PM
Do you have any pics of that header. I live nearby maybe if i decide to get it i can pick it up
1990 Civic HB
Old 10-18-2002, 12:37 PM
EF_LSVtec's Avatar
Dont have one on file but I'll take a pic of it tonight...Where you from? If you're not too far, I can drop it off and you can check it out or even use em and find out if you like em. Its just sitting in my garage.
AF Bay Area Crew
Retired SOLD 1/08
Old 10-18-2002, 10:01 PM
Im in salinas, but i go up to San Jose every so often and next weekend im going up to Sac for the Grudge night at the track. Maybe when i see the pic ill decide wether to meet up of something.
1990 Civic HB
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
