Old 10-16-2002, 09:50 AM
spotovi spotovi is offline
Overclocking?
Hey,
So what do you guys think about overclocking an Intel. I have a PIII-450Mhz, TNT2, on a Asus P2-99. I overclocked my FSB to 133Mhz and upped the voltages. The multiplyer is locked on my PIII so it was 4.5X133=598Mhz. I ran Quake on it and 3Dmax with good results. It ran ok but it really didn't do it for me and I set it back. I figured it's a good thing for big processes or games but to run it all the time like that, naaaaaa.
Spotovi.
97 Integra, 10th Anniversary Addition.
(RS with Non-Leather GSR interior)
B18B
K&N CIA
Custom Bent SS Cat-Back w/SS Dragon Style Muffler (4.5 Inch tip).
Stock Suspension
Stock 14" wheels
Goodyear Eagle HP
Stock Brakes
Old 10-16-2002, 12:14 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
As long as you aren't overheating your processor, PCI, and AGP bus there is really nothing wrong with it. Since you have an E class P3 you can overclock quite a bit. Just watch your temps.
Old 10-16-2002, 01:55 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
Try unlocking the multiplier. Search the internet maybe you'll find a trick to do that for your setup. Only if you unlockit you'll be able to properly overclock. Also as poly said wach your temperatures. Get a bigger cpu cooler and put an active cooler on the chipset.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 10-16-2002, 02:13 PM
I'm to understand that with most Intel PIIIs there is no way to unlock the multiplier. AMD and various others are adopting the same methods as well. I think it's AMD chips that can be unlocked with a pencil or a soldering gun or something like that. It sucks that I can't overclock for real but I'll take what I can get. Cranking up the FSB freq's is not that bad.
Anyone know about unlocking the unlockable?
Regards,
Spotovi
B18B
K&N CIA
Stock Suspension
Stock 14" wheels
Goodyear Eagle HP
Stock Brakes
Old 10-16-2002, 11:16 PM
Polygon's Avatar
The Red Baron
I hate to say, but there is no way to unlock the P3s, none that I have heard of and I know a lot of P3 overclockers, they have to resort to taking the FSB up.
Old 01-17-2003, 12:56 PM
Chris's Avatar
Chris Chris is offline
Oldie
Send a message via AIM to Chris Send a message via MSN to Chris
Yup, Athlons can be unlocked with a pencil Athlon XP's need a window defog kit and crayons (there r other ways....)
But I would say to overclock, if ur computer dies, it wouldnt be much to get a new, much better one.
Some Intels are unlocked, but they are special ones for use by Intel; only a few have made it out......
You can live in a car, but you can't drive a house!!
MSN: [email protected]
Old 01-18-2003, 08:48 PM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
I don't think there is a way to unlock the Intels, but if you figure it out, make sure to upgrade your cooling system. I'd add fans and get a better heatsink for you processor. They also make heat dispersment equipment for memory, hard drives, and graphics cards. Check out Tiger Direct . They usually have pretty good prices. Plus, if you kill your computer, you could go online from another computer and find parts to repair it
Old 01-22-2003, 10:11 PM
Webmaster_Zeus Webmaster_Zeus is offline
Its impossible to unlock intel cpus as they made it in the die, so its all internal and was locked during manufactoring process.
To unlock AMD cpus u need some sort of conductive material, mainly to join the bridges together. The usual method works, but needs a steady hand.
If your planning on overclocking, maybe try changing the voltages, n making sure the divider for the pci r set correctly, otherwise u might get artifacts from your video cards, n sometimes could result to damage of parts.
overclocking a toothbrush? kittedb18bt COMPLETELY off-topic 5 10-30-2004 12:33 AM
Overclocking Athlon Gotti COMPLETELY off-topic 31 10-19-2004 07:51 AM
Overclocked And TurboCharged Underground_Killah Introductions 0 07-24-2004 01:11 AM
Lets all overclock! Chris COMPLETELY off-topic 30 10-09-2003 07:50 PM
