Old 03-15-2002, 11:03 AM
Chris's Avatar
Chris Chris is offline
Oldie
Send a message via AIM to Chris Send a message via MSN to Chris
Talking Lets all overclock!
Overclocking is fun Unfortunately, on my moms comp, the bios doesn't support overclocking
But the motherboard for my dads future comp does (in nice 1mhz increments, which is even better!)
Now, what is overclocking?:
Overclocking is when you tell the processor to do more than it is supposed to do. This makes it faster. You should have a massive heat sink and fan, though, or the extra heat could melt the CPU, creating a several-hundred-dollar piece of jewelery. Also, each chip has its fail point. When you buy, say, a 1ghz CPU, Intel may have tested it and found it would work up to 1.31ghz before failure: ie, it wouldn't work right and would crash, necessitating a reboot. But you don't know the failure threshold, and if you brougt it up to 1.3ghz, it might work fine, but if you brought it up to 1.35ghz, it might start crashing. So just keep adjusting it, and once you've found the limit, tone it down about 5%, just to be safe and trouble free. And Don't overclock if you dont need to (ie, you will only be using Corel Wordperfect, or solitare, during that session)
To overclock, go into startup when you boot the computer (usually just press delete of F1 alot). Once there, find the overclocking option, and adjust it. Then save and exit
So, how much do you overclock?
You can live in a car, but you can't drive a house!!
MSN: [email protected]
Old 03-15-2002, 03:35 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Sometimes, overclocking too high can cause massive problems. I've heard rumors that GeForce cards do not like overclocking...
Old 03-15-2002, 09:19 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Well when you overclock the CPU you overclock the PCI and AGP bus as well. There is no way o cool them. Which is why I don't, because I only have a 6x multiplyer I could get maybe 50MHz before risking damage. But say a P3 with a 100MHz bus, they have an 8x miltiplyer so they can overclock much higher.
Old 03-16-2002, 09:53 AM
jaxle jaxle is offline
Send a message via AIM to jaxle
ive overclocked my duron 800mhz to 1.1ghz, but dont overclock it any more cos fan was always too loud and 800mhz is good nuff for me
93 civic lx w/ z6 tranny
88 buick century 4d wagon woody
Old 03-16-2002, 02:54 PM
ACCORD EX's Avatar
ACCORD EX ACCORD EX is offline
Send a message via ICQ to ACCORD EX Send a message via AIM to ACCORD EX
be carefull when overclocking AMD 's they get pretty hot !!
the best CPU's i ever over clocked was the intel celeron's ! but doing it with the old way ! ( jumpers )
MIKE
THE BEST 3 GEEZ BOARD
MY WEB SITE
3 geez member since October 4 th 2001
Old 03-16-2002, 05:28 PM
CivicEx95's Avatar
CivicEx95 CivicEx95 is offline
Banned
Send a message via ICQ to CivicEx95 Send a message via AIM to CivicEx95
I don't think overclocking is as common anymore, because the processors are so fast now. Not at least like the old days when everybody was getting a 300 MHz Celeron and taking it to 500
Old 03-16-2002, 11:02 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
This would explain why my screen went black when I used the gigabyte supplied software to wind my 950 duron up to 1100mhz.
Old 03-17-2002, 05:25 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Geforce1 DDRS are the only ones that really like to be overclocked. I got another 15FPS in Quake 3 when I overclocked mine.
I soft o/clocked my Celeron 500 to 566 (off the top of my head) but then it locked.
I won't over clock my Athlon 1.4 at all as it runs at 56 degrees as it is with a volcano HSF and 2 extraction fans cut into the case. Maybe if I decide to watercool I'll do it, but I'm not really into it anymore.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 05-04-2002, 12:25 PM
darklight darklight is offline
hrmm sounds like a good idea...i have a 800mhz celeron and i dont know what it can handle but what kinda temperature do i need to keep it in?
Old 05-04-2002, 10:10 PM
Chris's Avatar
Oldie
Yea, when I had a PCI video card (16mb Voodoo 3), my screen was always black. I couldn't even get to the BIOS to change it back But, there was a jumper on the mobo to restore default settings, so all was well.
Now, it just doesn't like it. I think the RAM is the problem, as windows starts to load, but never finishes. That was overclocking my system bus (max, 1.91 ghz on my Athlon XP 1800).
Then I just switched my CPU VCORE SELECT. It starts a 6, and goes to 14, giving a range of 800 to 1860 mhz cpu at stock system speeds (total, 2.3ghz CPU. Which would probably kill it, as it is 50% higher than stock) I was thinking of keeping it a 13, giving me 1.73 (200mhz higher). I have a ThermalTake 7, copper fins with a 53cfm fan on it. And the chipset has a heatsink and fan. It is weird though, because windows and startup don't recognize the processor as being faster. So I am leaving it on 'default' for now till I figure out what is wrong. So I will leave it overclocked a measly 40mhz for now
Old 05-04-2002, 10:34 PM
swedish swedish is offline
Thanks dill hole, i hit f2 to get into setup (windows me), got a keyboard failure and it screwed up the mouse. I was actually gonna "underclock" because my video card has been goofin since got a new format for it.
"One great big festering neon distraction,
I've a suggestion to keep you all occupied.
Learn to swim."
Old 05-06-2002, 11:23 AM
Chris's Avatar
Oldie
The only reason I can think that happened is if you have a wireless keyboard. Otherwise, I would suggest just setting a jumper to restore default BIOS settings if you really want to underclock it.
Old 05-06-2002, 11:30 PM
so what is a good temp for my 800 mhz celeron, i look in bios and it says i can do like 14x regular speed which is preety fast, i dont think it would be a good idea tho.:smoker2:
Old 05-07-2002, 12:48 AM
Polygon's Avatar
The Red Baron
Well, 120 F is about as hot as you want to get. Celerons handle overclocking very well.
BTW, I just read your sig.
Old 05-07-2002, 12:18 PM
Chris's Avatar
Oldie
That 14X faster is the speed your CPU is told to run in relation to the bus. You probably have a 100mhz bus, so yours would be 8X by default. So 14X would be 1.4ghz, or 1400mhz.
PS, I know someone with an 800 that runs a 1100. But thats just him.
