Old 04-20-2007, 03:17 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Storage detected but doesn't display
I had a really nasty virus and I had to recover, and my college internet was disconnected, a big ordeal, but the thing that pissed me off the most, I saved the files I wanted to keep on my 160GB NetDisk and now, I plug it in and it recognizes the storage but doesn't display it in My Computer. I only plugged it in on my friend's PC and the same thing happened. I really need to get these files.
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 04-20-2007, 04:05 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Storage detected but doesn't display
So how do you know it recognizes the storage but you can't see the drive show up in My Computer? Do you get the "Removable device" icon or a window that asks you what to do with the device when it is connected?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-20-2007, 04:51 PM
Dyno247365's Avatar
yea that 'removable' icon and also the sound that says something was connected.
Old 04-20-2007, 04:53 PM
BeZerK2112's Avatar
BeZerK2112 BeZerK2112 is offline
380HP Isn't Enough...
Did you try getting some drivers for the removable drive.
WHAT KEEP IT STOCK! Well that takes the fun out of it.
[center]
99 Maxima - View the Project at CarDomain
Old 04-20-2007, 06:16 PM
Dyno247365's Avatar
downloading now, I'll see if it works, the thing is this is an auto-detect model, works on a lot of pcs readily.
Old 04-20-2007, 06:20 PM
drunken monkey's Avatar
Razor Sharp Twit
have you tried using a "proper" usb port and not off a hub?
sometimes, if you've got too many devices plugged in, things like usb drives don't like working properly.
AF's Guidelines
Read them.
Old 04-20-2007, 06:57 PM
Dyno247365's Avatar
It's not a hub, it's the actual USB port, There's 6 I think. Anyway I installed the website's driver and went to register the hardware (cannot communicate with device)...are you f%$^$ kidding me??
Old 04-22-2007, 01:58 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Check Device Manager to check if it's installed properly, most USB drives don't need drivers in XP.
Then have a look in Disk Management to see what it says under the USB removable storage device, it could have assigned it a drive letter that you have assigned to a network share, or it could have problems and need you to do something further.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 04-22-2007, 02:15 AM
Dyno247365's Avatar
That should be impossible because I just restored my computer, and because it wouldn't work on my friend's pc either.
Old 04-22-2007, 07:38 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Have you looked in Disk Management? Post a screenshot.
Old 04-27-2007, 12:43 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I think OZ is right. I think you have a the removable drive using the same drive letter as another drive. All you need to do is change the drive letter. Also, if there is some sort of partition problem it will tell you in there.
Look in the disk manager.
