Old 04-16-2007, 07:33 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Car Suspension Question: need answers quick
Hi Guys,
I am a car enthusiast, but don't pretend to be a mechanic, or knowledgeable about the mechanics of a car in any way.
Today I dropped my car off to get new suspension fitted - springs, shocks, bump stops etc because before it was on lowered spring without revalved shocks and the ride was terrible.
The guy fitting them just rang me and told me that I need new rear bump stops, 3 new engine mounts and new belts at the same time for an extra $500.
Now second gear does move around a bit when backing off, but surely there would be something badly wrong if it had 3 broken engine mounts???
I have no way of knowing whether the belts need doing or not.
Am I being ripped off?
(I know this is the wrong forum, I just need some answers quickly before I pick the car up this afternoon - I'll move it later)
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 04-16-2007, 07:50 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Car Suspension Question: need answers quick
The belts you can tell if they have any cracks, rips, tears, burs, etc...
As for the motor mounts, sounds a bit sketchy to me...does the engine vibrate a lot while your its idle or driving?
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 04-16-2007, 07:54 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I would say it's a possibility. What year is your car and how many miles?
*Under Construction - New sig to debut*
Old 04-16-2007, 08:16 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
It doesn't seem to vibrate any more than it ever has.
It's a 98 model, a cough under 150k kms.
Old 04-16-2007, 09:05 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
engine mounts are usually made of rubber, and over time they rot and disintegrate. this is clearly visible though, and you'll see if they're cracked or not. belts have a lifespan or 15,000-30,000 miles, so check your service book for when they were last repared.
get the new rear bump stops fitted now, as they have to be done while the suspension's off, and you don't want to pay someone else to drop the suspension, fit new ones and re-align everything later on.
take it so a main dealership or trusted garage for a second opinion on belts and engine mounts.
Seatbelts Saved My Life
Old 04-16-2007, 09:16 PM
drunken monkey's Avatar
Razor Sharp Twit
if the car's been runing on lower springs without stiffer shocks then it's possible for the bump stops to have been taking some abuse during that time.
might as well take the time and change them for some poly' ones.
AF's Guidelines
Read them.
Old 04-16-2007, 10:18 PM
Yea I agree with everyone, but definitely do a quick visual check of the belts and mounts. Its more then likely that the mounts are fine.
95 Eclipse GS-T
Currently:
Soon lol
Old 04-16-2007, 10:54 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Hmm...the body started rubbing on the tyres about 2 months ago, which was the catalyst for getting the new suspension in the first place. Is it possible this was a symptom of one or more of the mounts breaking?
Thanks for your thoughts so far everyone.
Old 04-16-2007, 11:26 PM
alphalanos alphalanos is offline
If you are referring to the motor mounts, no that has nothing to do with ride height. I would get the bump stops done, but you can check the mounts and belts yourself pretty easily to see if you actually need them.
96 EJ6. Future home of boosted B18C1.
Old 04-16-2007, 11:39 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
It's very possible that the motor mounts are shot, but they are not super important to replace. It's one of those things like if you want to spend the money now go for it, otherwise it can wait and you can maybe get a second opinion on if they are really bad enough to replace. You would probably notice a difference though if you had them replaced either way.
The belts would be obvious. Cracks or wear is easy to tell and I would suggest replacing any belts with even a medium amount of wear, as they tend to go south quickly once they hit that point.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 04-17-2007, 01:45 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
OK, so the belts probably did need replacing and there's a good chance the motor mounts were shot too. Maybe he was telling the truth and not trying to rip me off.
The last motor mount arrives tomorrow, I pick the car up tomorrow afternoon.
all.
Old 04-17-2007, 03:36 AM
taranaki's Avatar
taranaki taranaki is offline
Banned
Be sure to ask for all the worn parts that were replaced.
Old 04-19-2007, 06:05 PM
lamehonda's Avatar
lamehonda lamehonda is offline
He will probably just put them on a belt sander and use them up.
1987 Honda Accord LX-Dead
1999 Honda Accord EX-L 5 sp-Sold
2006 Subaru WRX Wagon 5sp-Sold
2005 Nissan Frontier ext cab 4x4 4.0L-Sold
2006 Kawasaki Ninja 500r-Sold
2004 Yamaha FZ1 Silver/Black- Sold
2008 Mazdaspeed 3-In the driveway
