Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-02-2007, 11:38 PM
Canuck5056 Canuck5056 is offline
Inside lights won't turn off?
Driving a 94 Camaro and the inside lights won't go off, the reading lamps on the rearview mirror and the backlight. I've tried everything - turning every switch on and off, turning the car on and off, etc. Nothing works.
Help, please! I'd rather not have to bus to school tommorow because my freakin' battery ran out.
Old 04-02-2007, 11:43 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: Inside lights won't turn off?
Have you tried the interior light knob, to the left of the headlight switch? That happened to me once, I couldn't figure it out until I realized I had that knob turned all the way up, which in turn activates all the interior lights.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 04-02-2007, 11:47 PM
Yeah I've tried all of that, no dice.
If it comes to it, is it possible to open the mirror and backlight up and unscrew the bulbs?
Old 04-02-2007, 11:58 PM
blindeyed's Avatar
eBay aDdict™
You could just take the fuse out
- Jason
Old 04-03-2007, 03:30 AM
How do I do that?
Old 04-03-2007, 03:39 AM
blindeyed's Avatar
eBay aDdict™
You open the fuse panel.. look at the diagram and find the one that says "interior lights"... and then you pull the fuse.
- Jason
Old 04-03-2007, 03:54 AM
I didn't get the manual when I got the car, where exactly is the fuse box?
Sorry, I don't know a whole lot about the inner workings of cars. I wish I did, but I never really got around to learning.
Old 04-03-2007, 04:01 AM
Edit: Nevermind I found it. Which fuse is it? The diagram doesn't have one labelled interior lights.
Old 04-03-2007, 04:12 AM
Ok, I got the right one, it was Fuse 15A - "Courteousy." This turned the lights off, only now my keyless entry won't work.
Not a huge deal, but does anyone know how I'd go about fixing this - getting my lights working again and the keyless entry? I get the feeling it's a very minor problem but one I'll have to pay a lot to fix if I take it to a shop.
Old 04-09-2007, 03:40 PM
macker914 macker914 is offline
Lift the carpet up in the driver's floorboard.......
There will be a loom of wires under there......
Get a wiring diagram and find what color the wire for the interior lights is....it will be a ground wire that runs through-out the car....
That wire is grounded out somewhere in the loom.......start right by the driver's floorboard....you get in and out of there all the time, and the wires rub together every time you move around....
Try that, that is from experience with many vehicles.
EZ Online Mechanic
Ryan
'91 Chevrolet Camaro wit da Kenwood Hot
433 Stroker SBC (go-getta)
Old 04-14-2007, 06:22 PM
swennc swennc is offline
Since you were able to shut the interior lights off by taking the fuse out, I think that one of the door actuators is not closing all the way. This is the 'pin' that is near the door hinge that 'closes' the circuit when you close the door. Have you ever had any accessories hooked up to your entry system?
