Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 04-02-2007, 11:30 AM
Smeyer Smeyer is offline
rwd
would there be any way to put the F20c into my del sol
Old 04-02-2007, 12:13 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: rwd
Yes, you can do pretty much anything if you have the $ and the knowledge. I've even seen a couple del sols online that had engines swapped to the back of the car to make them MR. But there aren't any kits available to make it easy, it will cost an arm and a leg, and you'll need to know how to do it because there aren't any walkthroughs or anything like that. But honestly, if you need to ask if it can be done, you probably aren't going to be able to do it. There are a ton of things you need to do to get it to work right, and not just destroy a good car. I'd recommend just sticking with a realistic swap; B-series, or even H-series or K-series if you want a challenge.
Old 04-02-2007, 03:17 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: rwd
you CAN do anything you want, but it would cost a lot of money to do it...the more practical approach, which has already been done several times, is to swap an FWD (H, B, or K series) into the rear of the Del Sol. It would take a lot of money, skill and patience, but could be and has been done....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 04-02-2007, 05:06 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: rwd
If you want a RWD sol, here's where to look for an idea of the difficulty and cost.
http://www.honda-tech.com/zerothread?id=1266033
http://www.honda-tech.com/zerothread?id=939478
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
