Old 04-01-2007, 06:31 PM
Crazyboutmarcia Crazyboutmarcia is offline
Front end rattle
2002 Grand Caravan - rattles in the front...replaced sway bar bushings still rattles...bar links maybe? Wife is not happy with noise, making her own noise in response
HE
Old 04-02-2007, 12:15 AM
ronmar1 ronmar1 is offline
Re: Front end rattle
If it's a thumping bumping noise, could be the links. If it's a rattle, Id think something else. Brake calipers maybe? Try just a little brake pressure, see if it stops. If it does, you've found your problem.
Ron
Old 04-02-2007, 07:24 AM
Vats Vats is offline
Most likely the swaybar links. Turn the steering and once you can see the link, pull on it and you will be able to feel it move.
Old 04-03-2007, 06:34 PM
vamc's Avatar
vamc vamc is offline
Sounds like a stableizer(sp)bar bushing. My 2 cents.
Old 04-11-2007, 08:26 AM
MNGolfer MNGolfer is offline
We have a 2002 Dodge Grand. Front end rattle and the tie rod ends needed to be replaced. Also had the link bushings replaced earlier for knocking in the front end when going over bumps. Front end is rattle free now.
Old 04-11-2007, 04:56 PM
vamc's Avatar
Had the same issue with our 2003.
Old 04-19-2007, 06:24 PM
cchovaz cchovaz is offline
Had the same problem with my 97, turned out to be the links on both sides. The mounting holes had expanded and the links do not tighten properly against the Strut. They still do the job but rattle over ever bump. I replaced the stabilizer bushings first without loking at the links. Check the links and see if they are tight.
