Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 09-08-2001, 05:43 PM
video567 video567 is offline
need HELP AND ADVICE on old nissan! PLEASE!!!!
hi all i know im way out of my league here. i have an older nissan maxima 1984 but its a great little car. sun roof, stereo/cd 10 in speakers needs a new paint job .. my question is the other day i gassed it up came home from work parked it. the next day the car would not start. it tryes to start but it just wont turn over. i eventually drained the battery from trying to start it. i now just bought a new battery , changed the oil, replaced the spark plugs, and cables thinking it was due for a little tuneup.. and alas it will still not start it still has 1/2 a tank of gas in it. and i really dont know much more about mechanics except changing the plugs oils, cables and adding gas to it.. would anyone have any idea what else i could do maube get it staterted to atleast drive it to a mechanic shop? i hope some one here can help
Old 09-08-2001, 07:33 PM
bobo_80 bobo_80 is offline
Talking
well i guess...u`ll have the car towed to ur local nissan dealership and let them take care of it...!!!....yeh man ur max`s been driving u around for 16~17 years?....yeh it`s about time to get a major tune up for ur little baby.....good luck, well it might be a busted fuel pump...good luck!!^^
Old 09-08-2001, 11:45 PM
MAXIMASE2000 MAXIMASE2000 is offline
Smile
I guess you probably having problem with you alternater. Maybe I am wrong.:flash:
MAXIMASE2000
STILLEN AIR INTAKE
PIAA H4 SUPERPLASMA
SUPERWHITE TURN SIGNALS
CLEAR CORNER LENSES
20TH AE DOOR SILLS
WOOD DASH
Old 12-09-2003, 12:02 PM
bushmills bushmills is offline
Could also be fuel related, though you usually get a start al least for a little bit. Fuel pump would let the engine crank without turning over. That would make sense espesially after you had taken care of the electrical possibilities.
Good luck!
Will
Old 12-17-2003, 11:56 PM
borriss borriss is offline
Re: need HELP AND ADVICE on old nissan! PLEASE!!!!
If you can smell a gas when cranking (from exhaust, of course) it’s a good probability fuel lines work properly. Then check for spark. If no gas smell at all, here are 2 possibilities: fuel pump line (fuses, relay, wires, fuel pump itself) or injectors line: wires, fuses (if exist.) If it’s carburetor, you need cleaning job or new fuel filter (or both.) If fuel lines are OK, check for spark. If no spark, it could be the distributor, ignition coil or main wire from ign.coil to distributor problem. Weak spark = no spark. First of all check for blown fuses.
If it seems turn over slowly, most likely the starter is dying (the battery supposes to be good.) This is exactly what happened with my max.; 2 weeks the car’s been dead. Finely, changing the starter solved the problem. Hope this helps, good luck.
Old 12-21-2003, 08:22 AM
dlew329 dlew329 is offline
It could be the fuel pump. I think some one already said that. But anyway that happened to me and it ended up being the fuel pump. That is my suggestion, check the fuel pump.
need help and advice 97 awd ls 1iwilly M Bodies 3 04-05-2009 10:25 AM
Need help and advice on buying a new SLR camera. mellowboy COMPLETELY off-topic 4 05-17-2007 12:41 PM
Mustang owner needs help and advice Muscletang Mustang Talk 13 02-03-2005 02:04 PM
Need Help And Advice ndclub_stealth '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 01-13-2004 02:42 AM
