Old 01-10-2004, 06:02 PM
ndclub_stealth ndclub_stealth is offline
Need Help And Advice
Is a performance exhaust header really as simple as just bolting the old one out and bolting the new one in and do I have to do anything like resetting the ECU after header installation or is that only after a CAI installation? and, what shocks will go well with Drop Zone coil overs? I was considering Koni shocks. Can someone help?
Old 01-10-2004, 08:45 PM
BullShifter's Avatar
Re: Need Help And Advice
Yep, generally a header for Honda's is pretty simple to install unless the lower bolts are rusted, then you just cut them off. Use new seal between header & eaxhust - some require the O2 sensor wire to be made longer.
You should reset the ECU with any engine modification.
How do I say this nicely? Drop Zone's are not that great, but Koni Yellows would be a good choice. I'd suggest getting different springs, adjustable or standard.
Old 01-11-2004, 01:04 PM
thankx for the advice, good to know. a little worried about the coilover issue though, but definitely will go with the Koni's then. thankx.
Old 01-11-2004, 01:34 PM
um..by the way, and forgive any indication of ignorance here....but, what do you mean by new seal between the header and exhaust b/c I want to know if I'd have to be going out and buying something else before I to the switch? thankx!
Old 01-11-2004, 03:16 PM
Re: Re: Need Help And Advice
Seal/gasket goes between the header & exahust pipe to prevent any leaks. An exahust leak will sound terrible. Most new header's should come with the seal(s) needed.
Old 01-11-2004, 04:31 PM
emerge's Avatar
emerge emerge is offline
Send a message via AIM to emerge Send a message via Yahoo to emerge
I have DROPZONE coils on my car with stock struts and I ride just fine....
Stephen Gladney
Original PH Member
EJ8 Civic | AIM: nxzo | www.rtek.org
Old 01-12-2004, 04:34 PM
thankx for the info jackasssi, i will keep that in mind when i do the install. i just found out about Koni Yellows for my civic and got a good deal on them from a shop in Arizona, for $500 including shipping costs for a complete set of four, but the front pair are inserts. I'll shop around some more but someone told me I should go with them. what do you guys think? i don't want to take any chances installing Drop Zone coils on with a stock setup. i heard the shocks might blow. is this true?
Old 01-12-2004, 05:03 PM
95civicCX's Avatar
95civicCX 95civicCX is offline
You shouldn't have a problem with blowing your factory struts as long as you don't lower the car too much; or you could just have shitty road conditions, and if that's the case then blowing struts is inevitable(spelling may be wrong).
95 Honda Civic CX
SOHC VTEC
AEM High Flow Fuel Rail
B&M Adj. Fuel Pressure Modifier
B&M Fuel Pressure Guage
APEXi Exhuast
Del Sol Shifter
B&M Shift Stabilizer
H&R Race Springs
KYB AGX Adj. Struts
Eibach Pro Control Front Strut Bar
Arospeed Rear Upper and Lower Strut and Tie Bars
26mm Sway Bar
Rear Disc Brake Conversion (4 Tony)
Specialty Products Adj. Camber Kit
16 Inch Quantum Tec Alloys
215/40 Nitto 450
Old 01-13-2004, 02:42 AM
Stock shocks/struts should NOT be used with any type of lowering spring. They may not blow right away, but eventually will. Then you have to take it all apart again, put it back together, & another alignment. Ride quality will be very poor on stock struts because the struts can not control the lowering springs correctly. Remember, struts/shocks are there to keep the spring from bouncing forever & to absord the "shock" to the spring when hitting bumps or whatever the road surface may be.
need help and advice 97 awd ls 1iwilly M Bodies 3 04-05-2009 10:25 AM
Need help and advice on buying a new SLR camera. mellowboy COMPLETELY off-topic 4 05-17-2007 12:41 PM
Mustang owner needs help and advice Muscletang Mustang Talk 13 02-03-2005 02:04 PM
need HELP AND ADVICE on old nissan! PLEASE!!!! video567 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 12-21-2003 08:22 AM
