Old 10-10-2002, 09:36 PM
joecwlaw's Avatar
joecwlaw joecwlaw is offline
Question modelers Clear Decal Sheets with HP4500
Guys, I like to know anyone of you tried to use Clear Decal Sheets from Modelers before? The place I work has a HP Laserjet 4500 color printer, I am not sure whether this decal sheet can be supported by it? Your experience is appreciated.
http://www.hlj.com/cgi-local/hljpage.cgi?MDLD801
Old 10-10-2002, 10:29 PM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
if it were me, id try to print a little something on the paper and see if it runs or smudges when you try to apply it. from what i understand, laser printers are better than ink jet printers since they have less chance of running. if you use an ink jet printer, they suggest spraying something over it to prevent running or spreading of the ink. It's called liquid decal solution or somthing to that effect. hope that helps. i plan on using a color laser printer on some clear decal sheets as well soon too.
Old 10-10-2002, 10:47 PM
joecwlaw's Avatar
I saw the modelers decal sheet in one of the hobby shop here, and it says it requires a Thermal Printer.......but as I searched around the internet, it seems color laser printer and color laser copier can print on those decal sheet as well......I think it is worth to try as just 500yen VS 1600yen Studio 27 decals ......
Old 10-10-2002, 10:53 PM
Jay! Jay! is offline
Horizontally Opposed
LaserJet printer *should* be fine... It's worth it to test...
The advantage of the S27 sets are that they're pre-cut right to the graphic's edge.
Hierarchy of Subaru:
(Click to see mine!)
Old 10-12-2002, 02:33 AM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
i think Modelers are made for Micro-Dry printers such as Alps, but you still can print them on ink jets, ive tried it a few time with Microscales. just besure to spray an acrylic dull coat onto the decal sheet for the ink to bite onto.
Old 10-12-2002, 04:41 PM
Try this place
This website makes clear decal sheets for printers. im not sure it will fit yours, but you can check it out:
http://decalpaper.com
Old 10-13-2002, 01:27 AM
Re: Try this place
but you have to buy those in bulk.
Old 10-13-2002, 03:07 AM
What if I used a Ink Jet, but spray that "decal solution" on it?? Will this work?
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 10-13-2002, 11:33 AM
joecwlaw's Avatar
I just bought the Modellers Decal paper today (cost at USD4.00) . It comes with 2x B5 decal sheets......I am gonna make some good graphics and test to print next tuesday using the HP4500 Color Laserjet printer at office
Old 10-13-2002, 01:27 PM
nope, you should spray it with an acrylic dull coat then after youve printed the pattern seal it with a liquid decal film.
Decals - Clear coat & Sanding grit Zman007 Auto Collision Network 1 12-24-2010 07:52 AM
BMF Clear decal sheet for inkjet?? werdy666 Car Modeling 12 01-08-2008 12:07 PM
Need info on printing decals/printers/decal sheets bah humbug Car Modeling 5 10-15-2003 01:58 AM
Decal sheet with a bunch of numbers The Lambrusco Kid Car Modeling 2 08-21-2003 11:50 PM
Custom Decal sheets Honoturtle Car Modeling 0 08-14-2002 02:28 AM
