Old 03-28-2007, 10:46 AM
doberman_52's Avatar
doberman_52 doberman_52 is offline
Send a message via MSN to doberman_52
server and network questions...
I want to set up a file share/dedicated server. what I want to do, is hook it up through an existiing pc. So i have one network allready, and just want to add another pc through mine. From what I understand, its posible, but no one can tell me how or what its called. How would I do this? If anyone is confused on what I'm trying to do, Ill have a pic of the setup later.
1994 Honda Civic - D15B7 W/5 spd
2000 Olds Intrigue - 3.5
Cory
Old 03-28-2007, 02:11 PM
Re: server and network questions...
Ok, here is a pic of what I want to do...
- maybe copy and paste.
Would I just use a crossover cable to go from pc to server? And then turn on internet sharing?
edit: fixed your code
Cory
Old 03-28-2007, 03:29 PM
Gohan Ryu Gohan Ryu is offline
Does the server have to connect thru your PC?
If you can connect the server directly to your router you can simply enable folder sharing to share files:
1) On your computer called "Server" right click on the folder you want to share
2) Select properties then click the sharing tab
3) Enable sharing and give the folder a share name
Then from your "Other PC" browse the network neighborhood, search the entire network for the PC called "Server" and open it. You should see the shared folder there. You can map a permanent drive to it so you don't have to search every time.
If it asks for a userid and password you must create a user account on "Server" with the same userid and password you use to login to "Other PC".
I'm not sure if a crossover cable and ICS will work, it might. But either way you do it you'll have to enable folder sharing.
I'm assuming all PC's will be running some version of Windows for workstations, not Windows server right? If your "Server" pc is really running Windows server it's a whole different ballgame.
Old 03-28-2007, 03:35 PM
drunken monkey's Avatar
Razor Sharp Twit
question 1:
do you know what the difference between a server and a regular pc is?
AF's Guidelines
Read them.
Old 03-28-2007, 03:57 PM
Originally Posted by drunken monkey
question 1:
In networking terms a "regular pc" is referred to as a workstation. As I said earlier I assume you're not running any version of Windows server right? Just some version of XP Home or XP Professional?
Old 03-28-2007, 04:16 PM
Razor Sharp Twit
i was asking him because it would help understand what it is exactly that he wants to do. As you pointed out, if that machine is connected to the router, all he has to do is enable file sharing.
AF's Guidelines
Read them.
Old 03-28-2007, 04:28 PM
Toksin's Avatar
Toksin Toksin is offline
Non-profit Organisation
Send a message via AIM to Toksin
Just wait for Oz to see this thread, but explain again in detail what you want to do.
Old 03-28-2007, 09:49 PM
Yes. I can't run a wire from the router to it. And I'm not spending more money for a wireless card.
question 1:
From what I understand a file share/print server, its a computer that allows you to share and print files from many computers. A didicated server alows other people to play a game through it, it hosts a game. Thanks for fixing the code for the pic, what did I do wrong? And it wont be there in a few months cuz I dont know how long myweb site will last, I get it free from the state.
Both computers will be running XP Pro. I want to use it for file sharing and game hosting. Its going to be my old 900MHz PIII. Hopefully it will run ok. Ive got other hard drives than the 120 that was in it, I think 3 total will be installed once set up. Im setting this up next week once I get moved into the other room in my house. I thought file sharing was enabled by default in XP, but I could be wrong. If i were to get internet, how would I do that?
Cory
Old 03-29-2007, 12:00 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
No comment. Anyone who works in IT should be able to work it out.
This is possibly the stupidest thread in the history of the Computers/Electronics/Technology forum.
There are a million resources on the internet you can research yourself.
Fucktard.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 03-29-2007, 12:04 AM
Fucktard.
I searched, didnt find much. I don't know a lot about servers and what things like what I'm trying to do would be called. If you have a problem with my posts or questions, don't reply, that simple. I respect that you're a mod, but still, all your posts are mostly negative.
Cory
Old 03-29-2007, 12:35 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Instead of asking people who know what they're talking about how to do something, you tell us what you want to do then ask why it's all going to shit?
Usually you suggest the least logical method imagineable, that no one has tried or tested before because it's a stupid way to do things. You never show that you've researched anything outside AF, you usually say "I researched it, and it was all crap".
Then there's the fact you've "worked in IT" for several months.
So first you lie to us, then you're so arrogant that you make out that you've already worked out the solution, and you just need a few pointers on implementing it.
What do you expect us to say?
If it was me, I'd probably just plug the file server straight into the router using CAT5 cable.
You fucktard.
Old 03-29-2007, 01:01 AM
I'm asking how to do this.
I do my researching at school. I never found anything relating too what I am trying to do.
What? Ok. I'm asking how to set this up. a few people that I have talked to say its possible, they just dont seem to help me much.
I would if my parents would let me and if there wasnt a floor in the way.
You fucktard.
How childish. Seriously.
Cory
Old 03-29-2007, 01:24 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
"My parents won't let me"
"A new wireless card costs too much"
http://www.google.com/search?hl=en&q...ection+sharing
That's how you do it, but it's still a stupid, stupid idea. Your file server will be reliant on your desktop PC.
Old 03-29-2007, 02:19 AM
Toksin's Avatar
This thread..
DELIVERS
Old 03-29-2007, 03:53 AM
Razor Sharp Twit
which kinda renders the point of having a dedicated server redundent.
that's I asked if he knew what a "server" is.
AF's Guidelines
Read them.
